Question about Aiwa AV-D67 Receiver
Center speaker not working
Recently noticed center speaker not working. moved it to r/f location and it works fine. put advent speaker in place of center speaker and can hear it great. any ideas or thoughts? thanx.
  • 56 Answers
SOURCE: AV-DV75 center speaker works surround speakers do not
If all others had been fine before this problem arose, and you are sure that you haven't changed anything in your amplifier's channel selection menus, the problem might be deeper to solve! Try these out; 1-If the amplifier has a test menu to check out all channels plugged in, activate it. You must be able to get sound, which is like rustle, from each speaker. 2- Check your plugs, cables etc. be sure that there isn't any short circuit 3- Grab your amplifier's remote control and find the "channel selection menu" that allows you to increase and decrease volume levels for each speaker independently.
Posted on Apr 15, 2007
0 characters
1 Points
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
No sound from left fronts (A+B) in TV mode.
Just check the rca cables. Try wiggling the cables as well. If they are the plastic rca cables, they do to wear out quick.
If it is not the cables, than it is a shorted resistor in the channel sound output
Jun 17, 2009 | Yamaha HTR-5440 Receiver
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Check the rated impedance of your speakers. Use the manufacturer's rating. Don't try to measure it with an ohmmeter. This should be printed on the rear panel. If not, check your manual if you have one. The receiver probably shouldn't be connected to speakers rated any lower than 6 Ohms. If the speakers are 6 or higher, check your wires and connections for any stray strands that could be causing a short. I also have to wonder what "increase the volume substantially" means. Are we talking potential hearing damage? Maybe the receiver is saving you from your self.
Oct 09, 2007 | Onkyo TX-SR804 7.1 Channels Receiver
No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Sep 10, 2007 | JVC RX-770V Receiver
RX-668V - Center Speaker Channel
have a tech check your set it is a bad cap that that bias a very small voltage to that circuit or it could be cold solder.good luck.
Apr 15, 2007 | JVC RX-668V Receiver
Yes Mark, You have a problem with a componet with that center channel. If your not a tech, dont have a schematic, or dont have any training in troubleshooting solid state electronics, unhook everythuing and take it into a repair senter for an estimate, as unless you know how to chech the parts you can cause more damage to the unit as it takes one slip and boom, all gone. Good Luck
Jul 28, 2006 | Sony STR-DE575 Receiver
Aiwa AV-D67 Receiver Logo
21 people viewed this question
Top Aiwa Audio & Video Receivers Experts
Michael Thomas
Michael Thomas
Level 1 Expert
Are you an Aiwa Audio and Video Receiver Expert? Answer questions, earn points and help others
