Question about Canon Office Equipment & Supplies
Canon FX500 fax - I've changed the fine print cartridge, printed out 2 documents then it came up with "R'd in Memory". When I went in to print out these it came up with "Check 5100" and I have followed all the steps in the book (for over an hour) - there is and has been no paper jam, and still getting same. The printer cartridge will not move over to the left so I can check it.
SOURCE: canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Posted on Apr 26, 2007
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
SOURCE: "always getting check paper size"
the sensor flag at the rear paper path sensor is worn down too short. i have seen this many times
Posted on Jun 04, 2008
leroyal
  • 2120 Answers
SOURCE: My SF-5100 has stoped receiving faxes
Make sure you are set for AUTO RECEIVE.
Unplug power cord and re-connect. Do you have a DSL phone line?
Posted on Sep 05, 2008
marked
  • 6487 Answers
SOURCE: L800 manual
You can download the user manual for this, just go to this link http://download.canon.it/manuali_operatore/files/L800ugen.pdf
Posted on Dec 02, 2008
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
JX500 says "rec'd in memory" and "auto print
I can email you the user manual for future use. LBrown18062@hotmail.com Lawrence Brown
Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Sep 29, 2011 | Canon FAX-JX200
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
I have a canon pima mx340 printer/fax machine. How do you get a stored fx to print out
Printing a Memory List or Specified Document in Memory
1. Load paper.
2. Press the FAX button, then press the Menu button.
The Fax settings screen is displayed.
3. Use the button to select Memory reference, then press the OK button.
4. Print a specified document or memory list.
· To print a memory list:
Use the button to select Print memory list, then press the OK button.
The memory list is printed.
· To print a specified document:
1. Use the button to select Print specified doc., then press the OK button.
2. Use the Numeric buttons, or the button to select the transaction number (TX/RX no.) of the document you want to print, then press the OK button.
3. Use the button to select Yes, then press the OK button.
If you select Yes, only the first page of the document will be printed. If you select No, all the pages of the document stored in memory will be printed.
To print other documents, repeat the procedure from steps 2 to 3.
Nov 08, 2010 | Canon PIXMA MX340 Wireless Office...
How can i print my faxes that are received in memory? My fax is flashing - Auto Print Off - Rec'd in Memory. How can i access my faxes from there?
Here are the instructions from the onscreen manual from Canon USA.:
Printing or Deleting a Document in Memory
1 Press the FAX button, then press the Menu button.
2 Press the l_mark.jpg or r_mark.jpg button to select MEMORY REFERENCE.
3 Press the OK button.
4 Press the l_mark.jpg or r_mark.jpg button to select PRINT DOCUMENT or DELETE DOCUMENT.
bullet_s.gif If you select PRINT DOCUMENT: (1) Press the OK button.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number by pressing the Numeric buttons.
If you are unsure of the transaction number, print the memory list. See Printing a List of Documents in Memory.
(3) Press the OK button.
(4) Press the l_mark_s.jpg button to select YES to print the first page only, or press the r_mark_s.jpg button to select NO to print all pages of the document.
(5) Press the OK button.
I hope this answers your question.
Dec 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Memory full
check the manual, you can bypass the memory by printing direct, or just print everything in memory hre is the link
http://www.retrevo.com/
Jul 31, 2008 | Canon FAX-L1000 Plain Paper Laser
In Use/Memory FAX after changing ink cartridge
I had the same problem - it would not print the faxes as the machine would not recognize the generic cartridge - I had to get the official Canon cartridge to get the faxes to print out of memory.
Mar 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Received in Memory issue
=) SOLUTION!!! To print from memory, simply press the "FAX button on the front panel.
Then, press the "MENU" button. "1. Fax Settings" will appear in the display. Press the
"right" arrow key once so that you get "Memory Reference" to appear on the screen.
Press the "OK" button once. It will display "Print List", but you want to "Print Document",
so press the "right" arrow key until you get to "Print Document" and press "OK."
Once you are there, press "OK" again and the message "Print 1st page only?" It displays a YES and NO, so hit the left or right arrow key to choose. If you want to print the entire document,
choose NO and press "OK" Your document will print out!!! =)
Feb 10, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MP530 - Fax Memory is Full... How do I clear?
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Problem with fax Memory
This could be very simple. Check to be EXTRA sure that your USB line is NOT plugged into the fax line. (There's a little phone icon). That's what happened to me....boy am i dumb!
Oct 02, 2007 | Canon PIXMA MP530 All-In-One InkJet...
255 people viewed this question
old marine
old marine
