Question about GE 25952 Cordless Phone
House phone problem
My second phone doesn't work, it says "please register' and when someone is calling it doesn't ring like the first one
  • Anonymous Dec 03, 2008
    It is in the charger base but when I pick it up none of the buttons work, just says "Need to register handset"
  • 319 Answers
Please be sure to put the extra handset in the MAIN base station to register. They will not register in the small remote charger stations.
Let me know if that fixes the problem!
Best Regards!
Brian
Posted on Oct 29, 2008
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
My phone just stopped making or taking calls. One minute I called it (trying to find it), and it rang and registered a missed call. As I called it again (getting warmer/closer now), it just ended the...
you will need to find out if the simcard is active and if the phone has a signal if it does not then you will need to put it on the correct network
Aug 17, 2008 | Cell Phones
My house phone rings when someone calls but we can't hear it ring nor can we get a dial tone to call out
The ringing you hear when you dial your phone number is not actually your phone ringing but a machine at the phone company designed to give you something to listen to while they connect your call. I would say that your phone number is working, just not at your house. You need to call repair to trace your phone line and get it connected properly. Good luck
Jul 17, 2008 | Lands Phones
Extra handsets no longer seem to work. No ring and no line
Please be sure to put the extra handsets in the MAIN base station to register. They will not register in the small remote charger stations.
Brian
Jun 15, 2008 | GE 25942GE2 Cordless Phone System
Only rings one time
when someone calls, the phone rings only one time. calling other people works normally. Is this due to a lack of sufficient current to activate the bells of the three telephones we have in the house?
Jun 10, 2008 | Panasonic KX-TG5632 Phone
Registering
place on base the will register your handset but make sure battery is charged now to deregister hold # end call button together for 8 seconds follow instructions for deregistering then once done place on handset to register
May 31, 2008 | Uniden Cordless Phone
Does not ring
is the ringer on the base or phone on? check that first.if that's ok, then plug a regular corded phone into the phone jack and see if there is dial tone.if there isn't any, try other jacks in the house. if still not working, call your phone company.
wg
Feb 11, 2008 | GE 27998GE6 Cordless Phone
Uniden TRU9488 Phone
OU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Jan 28, 2008 | Uniden TRU9488 Phone
Will not ring
Had the same trouble reset the phone to defaults and do not register handset. Enter the area code and program the ringer volume. Use the PROG (MUTE PROG) key & the CALLERID-VOLUME buttons to make selections in the menu on the screen. to save the setting press the PROG key.
Jan 31, 2007 | GE 28021EE2 Phone
GE 25952 Cordless Phone Logo
181 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
