Question about Spectroniq PD-1100 DVD Player
Help wanted my dvd is not picking up any disc. evertime i insert a disc it reads bad disc. i tried cleaning lens n all that but it says the disc error. can u help?
  • 128 Answers
I think you have a bad lens. you can adjust the lens by opening your player and removing the disk tray. you will find two very small screw head at the bottom of the lens. you need to adjust them by turning them little by little 1 by 1 with a precision screw. and see if it reads any disk during each turn. if you have the cash you can just replace the lens with a new one.
Posted on Oct 29, 2008
Nec dvd rw nd-3450a write error
Open the dvd writer & clean the pick up lens with ethyl alcohol or isopropyl alcohol by using cotton swab.
Nov 24, 2011 | Dell Computers & Internet
When i insert a disc in my dvd player it reads "no
Hi mgarragh1,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I would advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 23, 2011 | Televison & Video
The dvd recorder will not recognize any discs. It attempts to read then states "no disc" or "no read". Can this be repaired or is the laser dead?
Hi! there are many reasons why a dvd is note reading. 1. dirty pick up lens, 2. defective spindle motor, 3. defective ribbon wire, 4. defective pick-up lens and defective mpeg board. but first things first try cleaning your pick-up lens with a cd lens cleaner.
Oct 16, 2009 | Panasonic DMR-E55 DVD Recorder
Every DVD I insert in my DWM 400 comes up
have you tried cleaning the pick- up lens with the lens cleaner.
Aug 04, 2009 | Sanyo DWM400 DVD Player
Bad Disc Error Message
The laser diodes which read the disc weaken over time and the lens can become dirty. Remove the case and you will see the 4mm dia. lens on the assembly rise up to read the disc when inserted. Eject the disc and lightly wipe the lens clean with a cellulose acetate Q tip or head cleaning cloth with just a small amount of disc/optic/lens cleaner. Try playing the DVD. If it will not read any discs then the laser diodes are to weak to read or there is a malfunction in the digital signal processing board. Unless it is under warranty, you will need another unit.
Jul 05, 2009 | Toshiba SD-4000
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
Every disc is a "Bad Disc".
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 12, 2009 | Recoton Advent Advent DVD-8200 DVD Player
My cyberhome CH-LDV-1010A dvd player does not go pass reading.
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Cyberhome CH-LDV1010A Portable DVD Player
Dvd recorder can't read the disc.
Try to cleaning the pick up lens with 100% cotton.
Dec 04, 2008 | Samsung DVD-R135
DVD Malfunction
If cleaning the lens doesn't help, you may have to try cleaning the slide that the laser assembly slides on. This would require taking it apart. When the DVD is inserted, the laser must read the index. If it can't then you get a "no disc" message. If this fails then the laser pick-up assembly may be bad or you have a problem on the circuit board. Stargazer Stargazer
Apr 22, 2007 | Apex Digital PF2025 20" TV
Spectroniq PD-1100 DVD Player Logo
121 people viewed this question
Top Spectroniq Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
