Windows xp service pack 2 I have to reinstall windows if I do so will I loose everything from my c drive
I have windows xp sp1 on my computer but also have the disk for windows sp2. I thought I could just upgrade to sp2 but I have to do a full installation, could you tell me if I do this will I loose everything from my c drive or wont I.
Please advise
Thanks
  • 1 more comment
  • hingy Oct 30, 2008
    thanks for the useful information I did what you suggested and it seems to have worked thankyou again hingy
  • hingy Nov 22, 2008
    Hi Wayneard this is Hingy would just like to say thankyou I took yr advice and downloaded from the net and all is good.
    Hingy :)
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Have you considered just downloading SP2 from the Windows Update and installing that way?
    President:
  • 1,901 Answers
Good job!
Guess I should of posted as solution instead of clarification. :-)
Posted on Oct 29, 2008
  • 39 Answers
You dont need the windows sp2 disk. all you need to do is go to:
http://www.update.microsoft.com
there you can download windows sp2. this way you will not loose anything. this is the safest way.
Windows does not giev me updates that I need to instal servicepack 1 and 2 needed to instal IE 9 or windows 7.
service pack 1 and 2 are old school, they are fading away unfairly
you need a copy xp sp1 ebay has it xp sp2 ebay has it once you have these service packs, unzip them load them, updates will start
for service pack 3 customize because you will not use everything
good luck
Dec 02, 2013 | Other NEW Fujitsu Amilo LA 1703 LA1703...
I had a working Dell computer - accessing the internet through a wireless router - computer became unbearably slow - re-installed Windows XP 2002 SP1 everything's fine except the network adapter that was...
You don't say what make/model of network adapter (NIC), whether it's wired or wireless, or if it was operating under the same service pack level before, so I have to make a lot of assumptions.
Is Windows really not recognizing it (ie: does it have an exclamation mark next to the NIC in device manager?) or is it being recognized by Windows but just cannot connect to the wireless router? If the latter, check your wireless configuration (SSID, WPA key, etc). Since you have WinXP SP1, it could be that there is not a driver for that particular NIC. Later service packs include updated drivers as well as bug and security fixes. Recommend you identify the NIC and if you have the driver disk for it, go into Windows device manager to select a reinstall from that disk. If you don't have it, use another computer to download its driver and after installing it and getting Internet access, you should also download and install the latest SP, which would be SP3.
Feb 18, 2011 | Dell Ethernet Card Network Adapter
How to create a bootable Windows XP SP1 CD
Using nero .
Step 1
Create 3 folders - C:\WINXPSP1, C:\SP1106 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP1
Step 3
You will have to download the SP1 Update, which is 133MB.
Rename the Service Pack file to XP-SP1.EXE
Extract the Service Pack from the Run Dialog using the command:
C:\XP-SP1.EXE -U -X:C:\SP1106
Step 4
Open Start/Run... and type the command:
C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP1 contains: Windows XP SP1
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip
Code:
Code:
http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.
Select File > New... from the menu.
1.) Select CD-ROM (Boot)
2.) Select Image file from Source of boot image data
3.) Set Kind of emulation: to No Emulation
4.) Set Load segment of sectors (hex!): to 07C0
5.) Set Number of loaded sectors: to 4
6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:
Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab
Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)
Set Format to Mode 1
Set Character Set to ISO 9660
Check all Relax ISO Restrictions
Step 5
Click Label Tab
Select ISO9660 from the drop down box.
Enter the Volume Label as WB2PFRE_EN
Enter the System Identifier as WB2PFRE_EN
Enter the Volume Set as WB2PFRE_EN
Enter the Publisher as MICROSOFT CORPORATION
Enter the Data Preparer as MICROSOFT CORPORATION
Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN
* For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab
Check Write
Check Finalize CD (No further writing possible!)
Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP1
Select everything in the folder and drag it to the ISO compilation panel.
Click the Write CD Dialog button.
Oct 11, 2010 | Microsoft Computers & Internet
I am trying to load programs from old xp to new I am trying to load programs from old xp to new xp. I get explorer version update not compatible, Then old computer has newer version than new computer. Can...
You cannot upgrade (as you say load ) from Windows XP to Windows XP. You simply cannot do this and there is no point in doing it as I explain. You can upgrade Windows XP to Windows Vista easily. In the case that you want to keep Windows XP and want to enjoy better security and new features than what you do is you go to "My computer" icon and right click it and then take properties of it. The new page that will open you carefully check for these SP1(Service Pack 1), SP2 (Service Pack 2) or likewise SP3.
If you do not find any (SP)Service Packs than according to your requirement you can download and install SP1 or SP2.
Caution: The third level service Pack for Windows XP is SP3. Microsoft has declared that it is not for everyone. I strongly discourage you to install SP3 unless you have a strong requirement for it. After that you can put your XP on normal regular updates from Microsoft.
Good Luck!
Aug 11, 2010 | Computers & Internet
My compaq Nx6310 notebook pc can not detect the USB ports when using windows XP
loadTOCNode(2, 'resolution'); To fix this problem on a Windows XP-based computer, you must be running Service Pack 1 (SP1) or later. To determine if you have Windows XP SP1 or later, click Start, click Run, type winver, and then click OK. If SP1 or later is not listed in the About Windows dialog box, then use Windows Update (http://windowsupdate.microsoft.com) to install the latest service pack before you try to fix this problem.
this will be the link : http://support.microsoft.com/kb/314634
ERNZ
Feb 09, 2010 | HP Compaq nx6310 Notebook
Wrt54g2 wireless doesn't get past the acquiring network address point.I'm using wpa2 with aes - wireless configuration is manual.
Unfortunately you did not give more information, so I 'm taking a wild guess here. If this solution does not solve you problem, let me know.
If you are running Windows XP SP1 or SP2, update the operating system to XP Service Pack 3 for best WPA/WPA2 support.
XP Service Pack 1 computers do not support WPA by default and cannot support WPA2. To upgrade an XP SP1 computer to support WPA (but not WPA2), either
  • install the "Windows XP Support Patch for Wi-Fi Protected Access" (link) from Microsoft, or
  • upgrade the computer to XP SP2
XP Service Pack 2 computers by default support WPA but not WPA2.
To upgrade an XP SP2 computer to also support WPA2, install the "Wireless Client Update for Windows XP SP2" (link) from Microsoft.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
Need a key for windows xp service pack 2
The Microsoft "Service Pack 2" is just a collection of program-updates and security-fixes for either the "original" Windows XP, or for Windows XP with Service Pack 1 already applied.
As such, it does _NOT_ require any "key".
Note that it's probable that Service Pack 2 will _NOT_ install on a "bootleg" version of Windows XP (original or SP1), because the SP2 update includes the Microsoft "Windows Genuine Advantage" update.
Jun 29, 2009 | Microsoft Windows XP Professional With...
How to solve hd audio failure error
reinstall the hd audio drivers .. and look for any errors in the device manager..
Jun 23, 2009 | Microsoft Windows XP Professional With...
Sound solution plz
goto control panel switch to classic view , double click add remove programs , then when the list comes up look for service pack2 and remove , then restart computer
Oct 25, 2008 | ASUS P5VD2-MX SE Motherboard
Which Service Pack is included with my Win XP Home Edition Version 2002?
Windows XP Home 2002 is Service Pack 1 only:
Buy a newer version.
Do not forget to rate the solution.
Many thanks.
Aug 29, 2008 | Microsoft Windows Xp Home Edition Sp2...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
