Question about Sharp VC-A410U VCR
Manual to hook up
I need a manual to hook up to my t.v. or cable box.
E-mail customer service at sharpusa.com
Posted on Jun 03, 2009
How to hook up cable box to model tz55x71 manufactured 2000 diagram please
You can Google the model number of the Toshiba for a 'manual" or owner manual which will show your set.
Usually with a cable box in goes to box and out to cable fitting on rear of set and set to channel 3. Output of a box with audio/video cables is same except they connect not to the cable fitting but to the rear inputs on back of set.
FYI most cable companies will come out, connect it and hook it up for little or no charge.
May 20, 2012 | Toshiba 50 Inch Big Screen Flat Tv Theater...
I lost the manual and need to hook up the vcr cable box and the tv.
You can download the manual from JVC here:
http://books.jvc.com/booklist.asp?Model=HR-A591U
if you reply with brand and model numbers of cable box, TV, I will help you with the hookup.
Apr 09, 2011 | JVC HR-A591U S-VHS VCR
Lost my manual I need to hook up to my cabel box. plus what cabels i need for my dvw5000
here is a basic diagram of cable connection from a cable box to a vcr and to the tv.diagrams_hookup_tv_dvd_cabl.jpg diagrams_hookup_tv_dvd_cabl.jpg
Feb 06, 2011 | Sanyo DVW-5000 DVD Player/VCR
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Trying to connect cable box....
You should be able to pick any open audio device unless it says pre-amp only. If your manual shows a connection for a CD player or similar device it should support the cable box.
Good luck and thanks for using FixYa
Mar 17, 2009 | Onkyo TX-SR500 Receiver
I just got cable and I cant get the channels to come in as cable channels. I lost my manual and have a universal remote?
Hi gail dahl,
I am happy to help.
From the Video Menu the Tuning Band must be set to Cable and not to AIR or Antenna. You will nee to run Auto Scan for channels from the Menu also.
I have provided a link to download the manual. http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL40XBR2&LOC=3
Let me know if you need further assistance and please rate this solution. FixYa.
Lone99star
Jan 31, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Need a Manual or help with System
YOU NEED TO HOOK YOUR RCA CABLES FROM YOUR DVD,TV,AND DIGITAL CABLE TO THE INPUT SIDE OF THE SURROUND. HOOK THE RCA CABLES FROM THE TV TO THE AUX SIDE AND THE DVD TO THE VCR INPUT, AND THE DIGITAL TO TH LD SIDE OF THE INPUT YOU CAN SWITCH BETWEEN THE 3 ON THE FRONT OF THE SURROUND.BY MOVING THE KNOB. YOU WILL GET NOISE FROM THEM THEN TO THE SPEAKERS.
May 24, 2008 | Emerson HT200 System
My cable box doesnt recognise my hd tv when i hook up the 2 with an hdmi cable
Check operations manual for HDMI hook up. Some cab/box have to be switched from menu. If you can't use HDMI, use component cables instead, there's not much difference in picture quality. Possible bad HDMI cable
Apr 21, 2008 | Televison & Video
Sharp VC-A410U VCR Logo
158 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
