Canon MP490 multifunction printer with MacOS 10.4.11. I downloaded the ScanGear software from Canon's homepage, but still there seems to be no recognition between the devices. Choosing the "Scan" option from the menu, and clicking "save to PC", the MP490 just says "preparing", but nothing happens. It goes back to scan standby, suggesting to place the paper on the glass and pressing "ok". Do that and repeat the process, but still nothing happens.
SOURCE: refilled ink cartridges on pixma mp490 ...will not print
I know this is frustrating. I am all for recycling and using refilled ink and laser toner cartridges. However, the manufacturers make most of their money from ink and toner sales. So, from time to time, they will encode or datecode cartridge chips. The only times I've been ale to get around this is by using at least one genuine OEM cartridge to trick the printer. If that does not work, try another et of refills, or you will have to use only OEMs.
Testimonial: "guru u da man. thnx"
SOURCE: Canon MP470 will not scan
Hello.
Scanning a document requires the MP Navigator EX software to be installed. If you don't have a copy, select: http://download.cnet.com/MP-Navigator-EX-for-Windows/3000-2094_4-10971618.html Choose Download Now and follow the process to install and run.
Scan pictures or documents using the MP Navigator EX software that was installed from the CD. Start the application, then click the "Scan/Import" button. Select "Photos/Documents (Platen)" to indicate you want to scan items on the scanner bed. Then use the "View & Use" screen to choose what you want to do with the scanned images. You can save them to your hard drive, email them, print them or, if the scanned document was a text image, use the Optical Character Recognition (OCR) feature to convert the scanned image to text.
Hope this helps.
SOURCE: I have a Canon Pixma
dpbrazie -
1. When you "select" your photo, select it NINE times.
2. Choose 8.5 x 11 paper
3. Choose wallet (x9) layout.
4. Print
HTH
Also, when trying to scan on different programs (NeoOffice, Preview, Image Capture), I can get the image preview to appear, but the "Scan" button in the bottom of the window is not highlighted and can't be chosen.
