Altec Lansing 745 ( 4 speakes 1 subwoofer)
I bought these speakes with my Dell 4500 back in 2003.....They slowly started fading in and out and now at maximum level, they are barely heard. What happened? What can I do? How do I do it other than paying somebody a ton of money?
  • 4 more comments
  • leut647 Dec 01, 2008
    Great sound but slowly faded out, still sound quality is good but barely audible very low volume, all controls to max
  • slandis1 Dec 08, 2008
    I have the same problem. Low volume with all controls at max.
  • Anonymous Dec 11, 2008
    Same problem. System worked great from 2004 to about 1 month ago (11/25/2008). Now speakers work at low volume... occasionally they play at full volume, then revert for 95% of the time.
  • Anonymous Feb 10, 2009
    Same problem. Controls at max, barely audible output. Used to be a lot louder.
  • Anonymous Mar 08, 2009
    Same, problem, low volume tried on other computers. Great speakers when they were working - just incredible.
  • ant_2069 Apr 17, 2009
    I have same problem as well
    doesnt look like there is any solution
    after 5 years throw them in the garbage?
    5 years I know is not 5 months but still!!!!!
I had the same problem w ith mine
Before giving up on them I decided i had nothing to lose by pulling them apart
Remove the base and screw hidden behind, reove the mesh cover and 4 screws hidden behind
Prise off the volume knob then unscrew the circuit board the vol control is fixed to
Now try the speaker whilst in bits
Mine miraculously worked at full volume straight away
I reasembled them and now they are fine
Just lucky maybe, who knows...but definately worth atry before you bin them
ANDY
Posted on Nov 28, 2009
I had the same problem, low volume with the control knob turn all the way up. I found the plug coming from the speaker with the volume control was bad. In the center of the plug there is a small rectangle shape piece of metal that plugs in. It was lose and when I touch it it broke off. There for I could not find a plug at Radio Shack, So I bought a speaker off of ebay, it has work great for a year now. Also you could wire this speaker direct to the sub woofer if you didn't want to but another speaker. Doug
Posted on Dec 31, 2009
No sound out of my Altec Lansing ADA 745. Computer Sound card is fine.
If other speakers are working, then 745 is defective or the volume switch is set to mute. Please check that, repair it if required.
Aug 27, 2012 | Altec Lansing Technologies Audio Players &...
Dell Altec Lansing ADA 745 speakers. The computer connectors are different than on my old Dell 4550. However when I connect to my new Inspiron 580 using the cable that is connected to the subwoofer, I...
Found your problem when trying to solve the same issue.
I have just got a Dell XPS tower and am having the same issue.Given that your post was 5 months ago, did you ever solve it ?
Charlie
Jan 26, 2011 | Dell ADA745 Computer Speakers
I have a set of 4 Altec Lansing surround sound speakers with a subwoofer i bought in 2003 with my dell computer. I can't get any sound from them. Do you have any suggestions? I tried hooking the system up...
If you are listening through headphones that are plugged in to the Altec system, then your problem is the amplifier is bad. Can't help you online with that. Sorry!
Feb 24, 2010 | Altec Lansing Multimedia Computer Speakers
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
Where can I download a driver for Altec Lansing ADA745 speakers?
HI, maybe theres been a bit of confusion but your Altec Lansing ADA745 speakers shouldn't need any drivers.
Its kind of similar to you plugging in a pair of headphones into your cumputer, they should work just fine.
Are you not getting any sound? Post the details of your PC (is it a dell?)
model number etc... and describe your problem
You probably need audio drivers for your audio device(inside your pc on your motherboard),
Aug 04, 2009 | Dell Audio Players & Recorders
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
My Altec Lansing ADA745 speakers have stopped working. I probably downloaded some other software that overrode the Dell speaker installation. How do I reinstall the Altec Lansing ADA745 speakers?
The speakers are probably fine. What you probably need to do is to reinstall the sound drivers on your dell.
You need the model of your dell pc and go to the dell website and find download and install the sound drivers for your system.
The model of your pc will be needed if any more assistance is needed.
Sep 16, 2008 | Computers & Internet
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
May 15, 2008 | Altec Lansing Multimedia Computer Speakers
Altec lansing ada 745
need to check your control center,then if thats not the one"it should be set @ 3/4 volume....
if no diff,,,,,then you need to go over checking every program that shares it,,,has their own volume control,,,somewhere there is the problem,,,maybe real player,,,media player,,,flash player etc...
thnks ttyl
Polywoggy1@hotmail.com..
Mar 10, 2008 | Altec Lansing Multimedia Computer Speakers
551 people viewed this question
 Grubhead
Grubhead
