Question about RCA P61940 61" Rear Projection Television
P61940 RCA TV does not turn on.
I have an RCA projection TV - model P61940. The TV no longer turns on at all. I checked the small fuse at the back where the AC wire terminates and it is not blown. Any suggestions as to what this may be ?
  • 1 more comment
  • mike francone Sep 04, 2006
    where would I get a schematic of the Television from. I have been looking on the internetwith no luck.
  • bigmonie Dec 13, 2007
    IT JUST WONT COME ON I PLUG IT UP AND I DONT HEAR NO SOUND OR NOTHING I HAVE A 61 INCH RCA P61940
  • De Jesus Jan 23, 2008
    The TV was working fine. We turned it off and when we tried to turn it back on again it would not come on. The fuse is good and there is power coming out of the power section.
HOW MUCH WOULD IT COST FOR THE SCHEMATIC
Posted on Dec 13, 2007
    President:
  • 3,130 Answers
Get a schematic and trouble shoot the main power supply if you have solid state experience. If you dont , PLEASE call a trained TV tech to assist you in this repair.
Posted on Sep 04, 2006
How do i find the capacitors? Because my p61940 wont turn on...it tries but only makes a noise and shuts off! Is the tv even worth keeping? Is it a cheap fix?
Good morning
as to your question if it's worth keeping most of these sets have fantastic pictures and are still out there working away . however that's a personal call if your ready for a new set .
its most likely a fly-back transformer its most likely a high voltage splitter block that has failed its accessible from the front behind the speaker grill and a center door its part no is 240619 and can be tricky in getting the wires back in so there is no arcing from the high voltage if you have to call a repairman expect around a 200 repair bill
Oct 14, 2014 | RCA P61940 61" Rear Projection Television
Tv doesn't come on. when tring to turn on you hear a buzz then it turns back off. Could it be the power supply board?
No,check for loose FBT-flyback tranformer connections a big black block of a plastic with a wire to a board section call highvoltage deflction board area.Useally the FBT is dead,require replacing and trouble shoot the deflection board area for other dead parts.Get quote prices from shops.Must hire a tv Tech. must do alot trouble shooting and replacing components.
Jan 01, 2011 | RCA P61940 61" Rear Projection Television
I was given a rca p61940 rear projection tv. The
It sounds like a convegence problem due to dust on the lenses. Clean the lenses with qtips and alcohol and then use auto convergence in the menu screen.
Mar 08, 2010 | RCA P61940 61" Rear Projection Television
I have a RCA rear projection tv. The colors need
If you can get to the menu you should be able to select options by using the volume and channel buttons.
Feb 28, 2010 | RCA Televison & Video
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
RCA 61" SOUND NO PICTURE HDTV
Contact a Technician to check your HV section of your TV, sometimes the heater on CRT have no supply.
Jun 01, 2009 | RCA P61940 61" Rear Projection Television
RCA TV MODEL D52W25
Take the back off the TV look where the wire from the power plug enters the TV. There is a small fuse on the board where the wire plugs into. If that fuse is blown, you have a power supply problem.
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
RCA P61940 61" Rear Projection Television Logo
244 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
