Temp is set to 50 degrees....it is eighty in here....help!!
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
SOURCE: I have a new Honeywell Round Non-Programmable Heat
Make sure the switches on the back of the thermostat is set for hot water heat. If you have more then 1 zone you may a stuck zone valve or a short in the wiring somewhere keeping the boiler on.
