Question about SanDisk Sansa e250 MP3 Player
Sansa freezes up
My sansa mp3 player freezes up when it is plugged into my computer for charging. I also have to try turning it of twice before it will power down.
Is the Sansa still accessible from the computer? If it is, then your gonna need the latest firmware update.
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
If not, then I suggest turning off the sansa altogether and plugging it into the computer. Then it should automatically turn on when plugged into the computer, and hopefully not shut off. Then do as stated in first few sentences.
CrossCut
Posted on Oct 29, 2008
My sansa mp3 has frozen nothing moves,it is on , how can i dislock it
Hi,the Sansa is a portable media player made by SanDisk. As with all portable media players, there may come a time when your Sansa freezes up for one reason or another. This can be incredibly frustrating. Fortunately, there are a handful of different methods you can use to unfreeze the player.
Instructions
Wait for the battery in the Sansa to die completely. Once the battery is dead, you can plug the Sansa into your computer and download a firmware update for your particular model (see Resources below). You can also remove the battery from the Sansa if you want to speed up the process.
Plug the Sansa back into your computer. If the computer recognizes the device, the player should begin charging right away. This will unfreeze your Sansa.
Hold the power button down for roughly 10-20 seconds. The Sansa should turn off. Wait a few seconds and then turn the player back on.
Hold down the center button and the menu button at the same time. Do this for up to 30 seconds while watching the display screen.
Hope it helped.
Thanks for using fixya.
Jan 12, 2011 | SanDisk Sansa Clip MP3 Player
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
My mp3 sansa won't turn on or charge.
If it freezes up, wont charge or just wont turn on... slide the power button up for 15-20 seconds then turn it on. That should work everytime. good luck
Aug 13, 2009 | SanDisk Sansa e250 MP3 Player
Sansa not charging
Try plugging in the sansa before you turn on your computer. Push the on button of the computer, then immedietly push the on button of the sansa.
Jun 11, 2009 | SanDisk Sansa E280 MP3 Player
I was charging my sansa mp3 player and now it does not work!!!!!!
the problem is when the computer freezes it sometimes can wipe the hard drive and can damage the mp3 player for good thus freezing it from turning it on and clearing the memory and thats it
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
Power issue
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 04, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Fuze not working anymore
My friend give me a sansa mp3 player BB0703UBB. When i charge it in my PC and i forgot to unplug sansa mp3 player BB0703UBB after half hour i plug it. But the power is not working. i cannot open and play it anymore. I try to insert it on my PC but then it says unknown device. HELP!
Jul 17, 2008 | Audio Players & Recorders
My sansa e250 won't charge
I had the same problem - the player needs to be unlocked (the little switch on top) to be able to charge - pretty stupid if you ask me but what can you do
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
59 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
