Question about Black & Decker 22" Electric Hedge Trimmer
Dirty cutting blabe
Please advise as how to remove the blade and how I can remove the "goo" (residue from cutting confedrate jasmine and legustrum) from the blade. I have tried everything imaginable and nothing works. Help!!!!
  • 398 Answers
Spray with wd40 before after every use in the future
Posted on Feb 26, 2009
How do I get the blade off my suffolk pUNCH ELECTRIC 12MOWER
Some of those blades are hard to get off. I put vice grips on the blade to hold it against the frame and put my long extension on my socket and sometimes put a pipe on to give me more pressure.
Just don't put too much pressure on to break something.
Mar 08, 2015 | Electric Garden
How do i remove sticky tape residue from wooden furniture
A commercial product such as "Goo Gone" works well. You can find this at your local hardware store or Walmart for example.
http://www.walmart.ca/en/ip/goo-gone-16-oz/6000093378251
Sep 18, 2014 | Furniture
Need to remove sticky residue from rock saw interior
I would use some sort of degrease product in the system to remove the oil residue . I believe that if you read the instructions it would say when cutting rock use only water to cool the diamond blade . Cutting oil is used only on certain metals to lubricate the saw edges and teeth as well as cooling and never in a concentration above 25% as it affects the cutting ability of the blade. For example concrete cutters use diamond saws and tap water when cutting
Mar 09, 2014 | Cars & Trucks
I've borrowed a circular saw (v old B+D 1 HP model). Can't loosen spindle bolt to remove blade: the blade is locked with a pair of locking pliers against the guard, but when I turn the spindle bolt...
you just have to look for little button close to blade, smash it, hold it while you move the blabe till gets stuck then you're ready to loose the blade! hope this help
Jul 24, 2011 | Saws
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
Sticker goo on car windows
try using a razor blade scraper, available at you nearby auto parts store....
Feb 01, 2009 | 2005 Chevrolet Aveo
Blades are not cutting
hi, yes blades can wear out but your sharpener should advise if there is a problem with them. check to make sure the clipper is moving your blades and your blade cannot be removed without depressing the latch. If your are experiencing tram lines with larger blades then it is more likely to be a clipper problem. However if your blades just wont cut i would recommend a new sharpener as it is a specialist area.
Jan 29, 2009 | Oster Golden A5 2-Speed Universal Motor...
Sticky label residue on software CD
try to lossen the residue with a little white spirit, before wiping clean with a damp cloth, always use soft cotton cloths and wipe gently
Nov 26, 2008 | Computers & Internet
A child's plastic cup top melted on heating element. . .how to remove residue
Gently scrape with a razor blade or paint scraper to remove the large pieces, then use some emery paper or very fine sand paper to remove the rest. Use care when applying any pressure on the element, and try not to leave any gouges in the element surface. I have also had good luck with a nail file. Hope this helps you.
Feb 01, 2008 | GE 24 in. Profile PDW7800 Built-in...
Black & Decker 22" Electric Hedge Trimmer Logo
151 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
