Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Honeywll Chronotherm 3 reading Hold AC
By awarner516 on Oct 28, 2008
thermostat is stuck on Hold AC reading and will allow me to change program info, desired temps, etc. but neither the heat or air will turn on
Solution #1
posted on May 18, 2009
Not Rated)
chrism07924
Rank: Apprentice
Rating: 0%, 0 votes
thanks jjplumb, right on the nose!
Was this helpful?
Yes
No
Solution #2
posted on Nov 26, 2008
Not Rated)
jjplumber
Rank: Master
Rating: 81%, 6 votes
the power to your furnace has been turn off. check the switch at the top of the stairs.
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
I have one humidistat honeywell H8908B which presently controlls honeywell humidifiers(HE440A ). I... (More)
Answer
I am getting six blinks on the call for service light after I push the reset button.What does that... (More)
Answer
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate... (More)
Answer
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell Power Humidifier:...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
