Question about Water Heaters
How to instal Generalaire 1137 Humidifier
Hi I just purchased Generalaire 1137 Humidifier all is OK but I need to know how I have connect 4 wires ( two red & two yellow )
You should have a plug for 115V, There should be two wires coming out of the bottom of the unit. These are for the humidistat. did you purchase this new??
Posted on Nov 10, 2008
I purchased a home a little more than a month ago that has an Aqualink RS8 system installed. A couple weeks ago, we noticed that in the indoor control panel was not lit, so we checked the outside panel. ...
open the aqualink control box remove the top panel see if the 4 pin red connector is plugged in and tight if it is check to see if the one inside is connected if ok check to see if wiring is cut
Sep 27, 2014 | Jandy Aqualink All Button RS Control...
How many wires does it take to wire a bosch ae125 tankless water heater
You need three #8 wires for AE125. Two #8 wires for AE115.
1) Copy following link for wiring information:http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
2) The AE125 has 3 elements, and requires 3 wires.Each wire is sized #8 copper, and is connected to 40 amp breaker, up to 100 feet. Over 100 feet, use 50 amp breaker and #6 wire. Oversizing breaker and wire is smarted and more efficient than undersizing.
3) Often a separate subpanel is installed to provide 3 extra spaces.
http://waterheatertimer.org/images/Main-subpanel-Tankless-600.jpg
4) Makes sure main breaker panel can accept additional 120 amps of draw without overampping panel ... and starving other appliances of full power.... that will damage appliances, overheat motors, and damage main panel and overheat main breaker. You want to oversize, not undersize electric service when installing tankless electric, which is why I do not recommend tankless electric installation, including issues of costing more to operate, and expensive repairs, and general money risk-nuisance of owning tankless vrs tank-type heater.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#stress
Dec 06, 2012 | Bosch PowerStar AE125 AE125 Whole House...
How do i install mechanical time switch
There should be 4 connections maybe 5
2 are for motor(phase and neutral) possibly labelled M. 3 other contacts will be C common NC normally closed and NO normally open.Connect your live wire to one M terminal then loop it to the C terminal. Connect wire to load or appliance to NO
Oct 17, 2012 | GE 24-Hour Mechanical Time Switch
Water heater timer not working or bad wiring?
10/15/2012
Hi Liz.
This is a live answer. And you can add a comment after trying following step, and I will comment back..
Replace battery, and then reset the timer using reset button located to left of display screen.
http://waterheatertimer.org/pdf/eh40-english.pdf
Oct 15, 2012 | Intermatic EH40 - Electronic Water Heater...
My water heater is leaking a lot. water comes from the down bellow. It started like three months ago but it is getting worst Do I need to replace it? how much it will cost a similar one?
It sounds like you need to replace it, Actual cost can very widrly depending on your location but I would say $350-400 is probably close. Plus installation unless you can do it yourself. Hope this helps. Thanks
Nov 23, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Intermatic WH40 Timer switch doesn't work even with manual 'on'. It has worked fine for years and now no power comes out of the timer. Power is ok going in. We have another WH40 purchased at the same time...
Typically, there are no lubricants applied to contacts - as they attract dust & dirt. Dust and dirt are poor conductors and can prevent good electrical contact from being made. Some lubes that you may see (typically in automotive lamp applications) is to help seal out water and prevent corrosion. Most switch contacts don't merely touch when they close, but rather perform a "wiping" motion. The two surfaces "scrape" across each other to help remove any foreign debris or oxidation that may be on the surface of the contacts. Additionally, quality contacts have a thin coating of silver, so they are not to be dressed with a file or other abrasive , etc.
The possible sources for the problem that I can see would be - in order of likelihood: (1) trippers, (2) loose field connections, (3) loose factory connections (4) failed timer switches.
Remedies: Make sure the trippers are not bent or damaged. Straighten or better yet - replace as needed. Make sure they are seated firmly against the outer edge of the dial and the thumb screws are made up tight. Check the connections at the terminal screws. Conductors should wrap 3/4 of the way around the threads of the terminal screws - and the screws should be tight. Check for loose factory connections - tighten any loose connections found. If these conditions are OK, the only thing left would be to replace the timer. Purchase a replacement and disconnect the field connections and remove the timer from the enclosure. Install the new timer into the old enclosure and make up the field connections at the terminals. Return the old timer in the new enclosure to the store or manufacturer for credit - or discard if out of warranty.
Don't even open the timer unless the power is off - unless you need to measure voltages, etc.
I hope this helps. Please rate this reply - thanks!
May 20, 2010 | Intermatic WH40 - Water Heater Time Switch...
Hi, our plumber has hooked up a new infinity xr-26 but the existing remotes don't work. He says it's a simple 2 wire connection but ther's no cirrcuit
Check with Rinnai to see if the old remotes are compatible with the new heater. Might mean upgrading the remotes too but the wires should be OK. Double check that he has actually connected the wires to the heater. Rinnai in Australia recentyl changed the connection point for the wiring. I can help further with this if this is the issue (not sure where you are!)
Mar 07, 2010 | Rinnai Digital Remote Water Heater Control...
Water heater ground
You have clearly lost your ground due to PVC. One solution would be to run copper ground wire from the hot water tank to the metal splice on each end of the PVC. It is not necessary to go all the way back to the breaker box.
Jan 23, 2009 | Water Heaters
Water Heaters Logo
285 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
