Question about Amana Refrigerators
My amana side by side fridge quits cooling for periods of up to 4hrs, at the same time the water dispenser doesnt work.. then after 4-5hrs the fridge starts back up.. runs for probably 16hrs and quits cooling again.
  • 1 more comment
  • staffeldt Oct 28, 2008
    My fridge quits cooling for periods of up to 4hrs, then start cooling again for periods of 16 to 20 hrs. The water also doesnt come out when this occurs.. There is power to the fridge when it isnt cooling.
    My fridge quits cooling for periods of up to 4hrs. Then starts cooling again. Also the water does not come out when the cooling stops. Is it the compressor
    My fridge quits cooling for periods of up to 4hrs. I have power to the fridge during this time, what could be causing the fridge to quit cooling..
  • 728 Answers
Your fridge may be overheating from an electrical short causing the fridge to go into auto shutdown so that it will not catch fire. You will need to get it checked up in a shop to confirm the suspicion and to get it fixed.
Posted on Oct 28, 2008
    Scholar:
  • 112 Answers
The cooling system and the water dispenser operate and are electrically fed independently. I would say your problem is in the power feed to the unit. Check to make sure you have a good power source.
    Scholar:
  • 155 Answers
Defrost the fridge for nearly 24hours.and adjust the temprature settings again properly in your fridge when you ON it.
thanks.
  • fixexpert Oct 29, 2008
    The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it
  • Amana Master
  • 19,396 Answers
The water dispenser and the compressor are separate circuits, check if the fridge has power or has no power at all during the time it is idle, test on a different power outlet.
  • Ginko
    Ginko Oct 29, 2008
    Hi, faults that can cause the fridge to stop cooling for a time can concern wiring, thermostat, defrost timer, compressor.
    The most common is probably a faulty thermostat, that stops the fridg for cooling and starts when temperature is too high.
    The pump to the water dispenser may be an unrelated problem, if it happens exactly at the same time when the fridge stops cooling, than that is weird, as the pump is on a separate circuit. If it is related it may be a bad wiring that shorts and stop some functions of the fridge.
    More likely the problems are unrelated, and the dispenser stops either because the lines are freeezing, or because the solenoid is defective or the pump is faulty.
    Here you find diagrams and a replacement thermostat.
    If you want to call a technician you can use the number listed on the owner manual.
Have an Amana fridge, 22.6 cu ft, 12 years old, side-by-side, water/ice on door. Freezer quit working over a 3 day period. All the food thawed. Not sure if the fridge part is getting warmer also -- not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2011 | Amana 22.6 cu. ft. Side-By-Side...
The ice dispenser and water dispenser on the door will not work
"Prepare for the worst" This is a problem i'm currently dealing with at the moment, ice maker thaw'd and refroze the ice as a block, binding the crusher turbine till it quit working. then water dispenser started spitting till it quit working, but anyway i disconnected the ice maker and water dispenser power hookup, because when i tried to use it it was drawing off the power of the fridge. now i'm to the point where fridge clicks like the relay is going out. in the back of the freezer below the ice maker tray i removed the clip or screw to where when it clicks i can hand spin the cooling fan on the click, and fridge starts up and runs, but don't remove this panel because having it on helps the air push into fridge compartment and keeps cooling elements from turning to a block of ice, " so long story short " its either your cooling fan or relay on chip board that starts cooling fan, i'm no expert but this is where i'm at hope it helps.
Jan 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
158 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
