Question about Video Game Consoles & Games
I would like to go on xbox on line with wireless but i dont no the ssid name routher can u please help
  • 34 Answers
Type this into an internet browser
try the different sites next to login until something comes up
Login http://192.168.1.1/ or http://192.168.0.1/ or http://192.168.1.2/
User name: (Leave Blank)
Password: admin
Go to your Basic Wireless Settings and you'll found Wireless Network Name (SSID) column. On there you can edit your SSID.
Posted on Oct 29, 2008
How to make a wireless connection to an xbox with a panoosnic Panosoic wireless Lan adaptor N5HBZ0000055
Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
Feb 05, 2012 | Dell Vostro Computers & Internet
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
What does SSID mean when entering a wireless network configuration Network name
It is the Service Set Identifier and is used to identify the wireless access point on the network - in common terms the name of the network device and can be used to connect to it
Jun 06, 2011 | Computers & Internet
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Cant connect Xbox 360 to this wireless router
Jan 15, 2011 | Linksys WRT160N Wireless Router
What is ssid
You SSID is simply the "name" of your wireless internet connection. I guess you are in the xbox live section of your xbox and you are trying to connect wirelessly. Just enter or pick the SSID of your connection to connect. You must also provide the password if your connection is secured. Please rate and comment.
May 17, 2010 | Microsoft Xbox Console
Having problems setting up my wireless networking adapter
What is the brand and model of your wireless router?
We need to know the settings (SSID, wireless security, security key/code) on the wireless router to match the settings on your xbox wireless adapter.
On your XBOX, go to System, then Network Settings, then select "Edit Settings".
Select the wireless network name or SSID of your wireless router. For the network mode, select Infrastructure. Select the security type if WPA or WEP and enter the Passphrase or WEP key.
Save the settings then select Test Xbox Live Connection.
I hope this works! Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated. Good luck!
Feb 14, 2010 | Microsoft Wireless Network Adapter Xbox...
How to hookup wireless internet
XBOX 360 WIRELESS ADAPTER
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
