Question about VIA SYBA Ethernet PCI Adpater Card
Error ox70080020 I get this error message when I try to down load service pack 3 or AVG 8.0
Strugling to download program
Post your OS, Service Pack if applicable. Have you done ALL your Windows Updates? Take a look at this procedure:
Apr 01, 2013 | Nuance PDF Converter Pro 8 Windows...
Error message after failed installation
Bro, I can solve this
Go to to watch a video of a Custom Gaming Computer with Great virus protection, and spyware..everything...The PC has like $4,000 retail for like $659. It comes with a ton of extras like 133 Nintendo DS Games, Fallout 3, Adobe CS4, MS Office Ultmate 2007, Roxio Ultimate 2009...and more...Nothing is trial-ware but yours forever.
Jun 01, 2009 | Internet Avg AVG Security V8.0 WIN - 2...
Trying to download avg 8.5 free edition
You cant put 2k service packs on XP, try xp's sp3, it may solve the problem
May 20, 2009 | Microsoft Windows XP Home Edition for PC
AVG Free install fails
Install AVG8.0, it should fix your problem
Feb 10, 2009 | HP Pavilion dv6000z Notebook
Help please
This is simply a bad download. You will need to start by completely removing the failed install, otherwise you're going to run into it all over again. Now, did you save the down load or just run it straight from the net? If it was a straight run, you may have encountered a slight internet glitch during the run. What you want to do is save the download to the desktop, then right click on it and run as administrator. It should install properly this way. Another thing is make sure that you don't have any other Antivirus, spyware, or adware programs on the machine. If you do, you will need to remove them, AVG covers them all. The reason you want to remove them is because they perceives the AVG as a threat, especially other Antivirus programs, not a harmful threat, but a competitor threat, and will stop the download or install. Antivirus companies, especially Norton, doesn't like to lose their customers, so they throw in these little blocking programs, in hopes that it will detour you from going to another.
Aug 08, 2008 | HP Pavilion dv6000z Notebook
I'm trying to uninstal AVG, but it says there is 1 problem and will not uninstal the program. can you help me uninstal this program?
Hello darrinmoen,
You Havn't specified, What is the problem exactly. I mean you have not specified the error Description.
But still The problem could arose while uninstalling Antivirus Program would be:
1. Any *.dll file missing from antivirus directory.
2. system file of antivirus missing from System32 directory of windows.
3. Any file that belongs to antivirus are not able to load while installinfg like uninst.exe.
4.Windows installer 3.0 is not installed on ur system
(Check out all the above including reviewing ur antivirus directory for uninst.exe file)
To solve this error you must do the following:
1. Run AVG antivirus setup program to repair. some times it doesnot give you the option if half of installed program have been removed from system.
2. Go to run type "regedit" and press enter
3. go to hkey_local_machine ->SOFTWARE -> and select AVG
expand trees of AVG.
4. Check for data path and its contents in AVG directory of program files, and also For UninstPath to varify that the uninst.exe in avg directory of program files is not missplaced
5. After doing the specified solution 60% are the chances that ur program would be uninstalled. else if it doesnot uninstall the program and gives the same error then Choose system restore tool.
For restoring do the following:
1. Go to Start -> All Programs -> Accessories ->System Tools
and select System Restore
2. Go to next window, Choose the restore point that was before installing of ur AVG Antivirus.
3. Select that restore point by reading the description.
4. Click next to restore.
Note: Your system will restart after choosing the restore point and clicking next. It takes some time to restore.
Most probably this tool will help you to remove this antivirus.
Remove it's entry from registry by Going to run type "regedit" and press enter
go to hkey_local_machine ->SOFTWARE -> andright click AVG
and select delete option to delete.
Gimme acknowledgement after removal
Aug 03, 2008 | Microsoft Windows XP Professional With...
Error: avgmfx86.sys starting service, error 0x8007007f
Error code 0x8007007f or error code 0x8007007e loadTOCNode(2, 'cause');This problem frequently occurs after you upgrade a service pack. After you upgrade, there appears to be a corrupted file, a missing file, or a file mismatch
That is what microsoft's website says about the error. Have you tried uninstalling and reinstalling? Also have you made sure you have all the microsoft updates available installed.
Keep me posted,
Jun 16, 2008 | Edirol UA-4FX External Sound System
Problem installing AVG free: error 0x800736b1
i have the very same problem- contacted AVG support but they replied whether i have registered with them.. no idea about what they mean.
Jun 01, 2008 | Computers & Internet
I cannot install avg 8.0.
For installin gthe avg 8.0 check the following:
1. Latest Service Pack for your OS
2. Check that the local disk c: is having free space
3. See that you had min. 128MB RAM
Let me know if your problem is solved and rate me as FIXYA!
May 27, 2008 | Computers & Internet
I am trying ti install agv anti virus i have completley unistalled norton but i kepp getting this error message action failed for file agvmfx86 sys starting service error 0x80070002
Always shut down all running programs before trying to install anything like AVG. If you already have an AV program, uninstall it before trying to install AVG.
If still having problems after doing that..... RE-Download AVG 7.5 FREE and try the install again.
Good Luck,
Please let me know your feed-back.
Technical Associate
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top VIA Computers & Internet Experts
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
