Question about RCA D52W19 52" Rear Projection Television
Powers on, no sound, no picture, powers off.
Our TV powers on by the front button, or the remote. The green light is on. No picture, no sound. Then it goes off. It will turn on again, by itself, no picture, no sound, then turns off. That's all.
  • 1 more comment
  • ccwright Nov 10, 2008
    same problem! Turn on power..green powerlight turns on for a few seconds then goes off. this happens 3 times and then the green light stays off.
  • dwbdjs Nov 11, 2008
    Exact same problem. Powers on with no sound or picture & green light on front for a few seconds.
  • kingofclubs4 Nov 11, 2008
    I have the same exact problem. I hope someone can find a solution. My TV is only 4 years old.
  • RCA Master
  • 5,138 Answers
On power/deflection board there is 3 capacitors that most of the time is problem cp150-220uf 16v and cp114 cp120 -220uf 35v. if cp150 is bubbled up on top it is bad,so replace other 2 caps in same circuit as well.
Posted on Dec 19, 2008
Mitsubishi TV How do I fix green blinhing light in mitsubishi DLP TV 52825
most likely its a bad power supply. the wd52825 is known for that issue. check youtube for repair videos.
Jan 28, 2015 | Mitsubishi Televison & Video
TV powers on, picture blinks once, screen goes dark with green power light remaining on steadily
What is the brand name and model number to your TV? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Televison & Video
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
How can i set up my direct tv remote to my Haier tv
How to scan for TV codes on your DIRECTV remote
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9-9-1, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
Feb 13, 2013 | Haier HL22XLE2 - HL22XLE2 22 LED-LCD TV -...
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Then enter 9911, the green light on remote should flash twice.
  • Sep 07, 2011 | Televison & Video
    Can set up th remote control for this tv with the direct tv cable remote
    Here's how to scan for TV codes on your DIRECTV remote
    1.Make sure your TV is turned on.
    2.Slide the mode switch at top of remote to "TV".
    3.Press and hold the MUTE button. This is located above the number 1 button.
    4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5.Then enter 991, the green light on remote should flash twice.
    5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
    6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    *If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
    7.When the TV powers off, press and release the SELECT button.
    *Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
    Mar 05, 2011 | Curtis LCD2425A TV
    Need rca crk17sa users guide for codes for Magnavox TV
    Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
    http://www.directv.com/DTVAPP/content/remote_codes
    Here's how to program your DIRECTV remote control:
    1. Press MENU on remote.
    2. Select "Parental, Favs and Setup"
    3. Select "System Setup"
    4. Select "Remote"
    5. Select "Program Remote"
    While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
    How to program the white DIRECTV remote to your TV
    1. Look up the control codes for your DIRECTV remote control.
    2. Make sure your TV is turned on.
    3. Slide the mode switch at top of remote to "TV".
    4. Press and hold the MUTE button. This is located above the number 1 button.
    5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
    6. Enter the first TV code you have. The green light on remote should flash twice.
    7. Aim remote at TV and press PWR button once. The TV should power off.
    8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
    If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
    If remote control fails to program using all available codes, try scanning for the code.
    1. Make sure your TV is turned on.
    2. Slide the mode switch at top of remote to "TV".
    3. Press and hold the MUTE button. This is located above the number 1 button.
    4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5. Then enter 991, the green light on remote should flash twice.
    6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    7. When the TV powers off, press and release the SELECT button.
    Mar 08, 2010 | Televison & Video
    RCA D52W19 52" Rear Projection Television Logo
    76 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
