Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
Water Stayed in dishwasher
Could you please advise why there is too much water in my dishwasher. The water did not drain. I do not know what to do in this case because .
Please advise ASAP i have this same problem - the dishwasher doesn't drain all the water out. we have the whirlpool gold quiet partner. we checked the drain hose & it doesn't seem to be blocked. our garbage disposal works fine. our sink seems to drain fine also. please advise us with another solution!!
thanks katie After washing, water standing in bottom of dishwasher. I dip the water out and take apart to get the water out by the drain. Keeps happening. Sink works fine. No clogs. No kinks in drain tube.
  • notquiting Dec 27, 2008
    I've just had a similar problem, I poured in CLR and after another normal wash, it seems to improve ......less water at the, maybe I should pour more CLR and hope it will dissolve the debris at the bottom of the drain?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
Posted on Sep 29, 2010
2 Suggested Answers
  • 185 Answers
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
Posted on Nov 08, 2008
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
The dishwasher works fine, but does not expel the water. please advise.
Feb 23, 2011 | Whirlpool Dishwashers
Maytag DWU6602AAE. My Maytag dishwasher (14 years
Feb 25, 2010 | Dishwashers
Water wont drain
Hi there....water not draining out is usually related to (a) a blocked drain pump...(b) blocked outlet hose.....(c) blocked drain outlet (under sink)...the tarmac smell is comming from the heat insulation at the rear of the dishwasher need to check that dishwasher is not overheating....
regards Sir Galahad
Aug 12, 2009 | Dishwashers
Dish Washer retains the water without draining....
the drain pump is fairly easy to replace. it locks into place beside the sump and motor. push tab in and rotate pump to pull out. you will lose water so have a towel handy. inspect drain hose for restrictions or kinks.
Jun 25, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher states there is a water leak when visually there isn't
Assuming that you have checked under the dishwasher for a leak (through a faulty sump gasket):
Since there is not actual leak, check the following:
-Confirm that the height of Drain Hose connection (sink-Drain Hose) rises greater than 20′ _minimum_ as it travels to the drain connection.
-If that does not solve the problen, it is probably a worn/broken Impeller of the Washing Pump.
Unless you are mechanicly incliend, a service call is probably the way to do. If you need further steps, please reply. Otherwise, after you ahve used the advise, please accept this solution.
Mar 28, 2009 | Dishwashers
Check your drain hose,it might be blocked with debris.Does your drain hose attached to your Disposal, you could also fill your disposal with warm water and flush it as well.
Post another comment if does not work, I shall suggest other things to check.
Jul 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
1,334 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
