Question about Maytag LAT2600A Top Load Washer
Washer trips circuit breaker
Upon filling to appropiate water, washer trips circuit breaker when machine attempts to engage agitation mode
    Novelist:
  • 145 Answers
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Posted on May 02, 2010
I have a MTW5620TQ1, The other night I turned it on to fill with water & the power shut off, it flipped a Circuit breaker. Now when it is turned on it will not fill with any water, hot or cold. & when the...
Sounds like a bad water pump, and or bad agitator motor if the washer will not spin. Breaker probably tripped due to one of the 2 drawing too much current.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Sears Parts Direct Agitator - 8578210
Electric box keeps tripping out when machine turned on
You have a short or overload fault in the washing machine that causes the circuit breaker to trip out and this prevents a possible fire.
Feb 20, 2013 | Computers & Internet
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
Washer sat in about 4 inches of rainwater water
Do you have friend who would take the time to open the machine.
4 inches might cause a motor short, it is iffy
also when the storm drain backed.. did it trip the circuit breakers that protects your washer
Jul 25, 2010 | GE Washing Machines
Washer filled up but will not agitate or
Does the motor run? May be a tripped circuit breaker on the motor. If motor runs, may be a broken belt.
Jul 27, 2009 | Washing Machines
Electrical Burning smell when agitating, trips breaker.
Send your complete model number, just to make sure we are working on same washer.
First check the lid latch switch by unplugging washer first and remove the font panel. Look up to where the switch is mounted. I am not positive that is your [problem but know there has been many problem with that switch. It will begin to melt ad cause the power to motor to be lost in a bad connection.
Mar 24, 2009 | Kenmore Washing Machines
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
NO Agitator, draining or spin
Since the breaker did not trip i am going to assume that the washer stopped because the motor overload switch tripped or contacts burnt. Was there any smell of any burning (electrical burning)?. It could have stopped because a contact on the timer got burnt too. Have a look also at the water level swirch
Regards
Oct 04, 2008 | Whirlpool LSB6200KQ Top Load Washer
Maytag LAT2600A Top Load Washer Logo
1,039 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
