Question about Bosch 24 in. SHU43 Built-in Dishwasher
How to find the water pump on Bosch model dish washer SHU306UC/U06
    Sniper:
  • 73 Answers
Take out the dishwasher, its on the bottom
Posted on Oct 31, 2008
Bosch Dishwasher Model SHU5315UC/U06 Looking for Cycle Buttons That are no longer avail #176079
There are several places on-line where you can find this parts. Depending on where you are. For example you can look up www.dlpartsco.com
May 08, 2016 | Bosch Dishwashers
No water is getting inside my Bosch dishwasher compartment. Water supply to dishwasher is ok. Checked hose at input of dish washer and water supply is ok. Could pump have packed in? Model 004 920 378....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Bosch Dishwashers
The dish washer runs but does not pump the water out sounds like the pump is runing and nothing seems to be plugged
Dec 31, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Wash cycle OK, but the drying cycle is faulty. The dishes are wet after 12 hours. Will not dry contents of washer! #SHU680SUC/U06
your heating coil has gone bad it`s that rod looking thing in the bottom of your unit under your spray washing spinner depending on the age of your unit your probley better off buying a new dishwasher
Oct 02, 2009 | Bosch Dishwashers
Bosch dish washer not washing
are any lights blinking is there an error code on the disp whats the model #
Jul 01, 2009 | Dishwashers
Bosch dishwater backed up/leaking
You may have upset the lower door gasket, a kind of "wiper" that keeps the water inside during wash/ Look for a wrinkel in it. Maybe push it down some. the track where it goes my be you can see and it will be self explaning. As for the water not draining.... A hose kinked, A pumpout drain valve not gettign power, I just had the same problem with mine and found a small piece of a plastic baggy in the pump sump covering part of the drain hole. And after that I had no drain and just squished the drain hose at the outlet. I suspect a buildup of grease or maybe some more plastic was inside the the outlet tube. Mine drains fine now. Look for these. And let me know please
Apr 05, 2009 | Bosch Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU5302UC/U06 dishwasher starts at 2H and eventually starts but continues for a long time at 1 without rinsing the dishes.
I had the same problem a few years ago and the tech replaced the control panel. No problems until....last night. Now a different problem.
Jun 17, 2008 | Bosch Dishwashers
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
188 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
