SOURCE: password reset
take it back to your provider and explain to them what happened they should be able to take care of it for you.
with the 4 digit numeric passwords on verizon while locked you could still call *228 (Over the air programming) select option 1 to re-program your phone and it would set the 4 digit lock code back to the last 4 digits of your phone number
SOURCE: Am not aware of aligning my screen on my HTC touch
you would be able to perform a master reset on your deivce and your device will reboot itself and when it comes back on it will be as if your phone is brand new and will have you do the calibration of your screen to realign the devices screen
1. Download the latest activesync and connect your mda to your computer and verify your device is connected(not as guest)
2. Perform a soft/hard reset on your MDA then tap your screen to start the screen alignment wizard
3. Download the remote screen alignment tool attached and install it on your machine.
SOURCE: I bought htc touch 2 T3320. mobile 7 month before.
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
I hope this will help in solving the problem.....
