Our Sharp inverter air conditioner unit AY-X075E AY-X095E has been working fine throughout the summer, & all the settings for cooling & drying are in good working order. However when switched on to heat the room, the red light comes on & the louvres move in to position, but after a short period of time the red light goes out & the yellow timer light comes on & flashes. Nothing else happens. Any idea of why this is happening & how to resolve the problem would be gratefully appreciated. Thanks
  • jorgen s Jan 22, 2009
    Hi
    I have exactly the same problem with the model AY-X095E. Did you find a solution?
  • Patrick Camilleri Aug 06, 2017
    I have the same, did you repair it,
Did either of you solve your problem as I have the same problem with my Sharp unit
Posted on Feb 18, 2010
Sharp AY-XP 12 ER indoor inverter showing -0 14 error
Sharp AY-XP 12 ER indoor inverter showing -0 13 error
Sep 11, 2013 | Sharp Heating & Cooling
The heating is not working at all on my fujitsu air conditioner
Should have an heating element inside...that one I think is broken or can be also the thermostat..
Jul 12, 2013 | Dishwashers
Sharp CV-P12Px not cooling
Sounds like an issue with the compressor. Have a service technician test the compressor.
Apr 30, 2012 | Sharp CVP12PX Air Conditioner
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
Air conditioning unit is not responding to the remote
If you can't change the settings manually, then the control pad is bad. If you can and the remote won't change the temp or mode then the remote is bad and will need to be replaced.
Apr 10, 2009 | Heating & Cooling
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Hi the outdoor unit turns on ( fan runs) the indoor unit does open, no heat or cold air blowing. In just fan mode the unit works fine etc speed setting ok. Its a sharp split type air model # ae-a244j...
My gut says that this is evidence of a bad control board(circuit board). As usual, double check that your batteries are good in the thermostat. I have seen some weird things happen when the batteries are low. This one may be a job for your local contractor.
Jun 23, 2008 | Sharp Heating & Cooling
Not cooling
1. check doors,windows,of room
2.if there is leakage freash air came in.so temparature can not maintend
Jan 30, 2008 | Haier HPAC99ER Air Conditioner
Sharp AY-A249J air conditioner not cooling
Maybe get an electrician to make sure the voltage is not dropping to low at start up.
Jan 14, 2008 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
1,445 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
