My MPMan F400 doesn't want to skip between directories and folders. DIR navigation is not working.
  • 3 more comments
  • Anonymous Dec 13, 2008
    The DIR explorer doesnt work on mine either.
    when i select it, I go back to where i come from. Its the same as pressing "exit".
    I will send it back i guess
  • nousbrunoy91 Dec 25, 2008
    same problem! !!!!!
  • sherman3810 Dec 28, 2008
    i have the same problem too. it sucks. i got loads of music and i need to use ti to go through it. it would really help if someone knows why?
  • saduser Jan 01, 2009
    same problem with F400 mpman, it doesnt show any music folder although everything is fine when connected to pc.
    please help
  • weeandykidd
    weeandykidd Jan 03, 2009
    When I Press DIR navagation it does nothing,
    ive tried tapping holding in pressing heavy+lightly,
    but nothing happens,
    possibly bad firmware?
    It's very irratating as i have over 500 songs on it.
Turn it on and plug it in transfer your folders and mp3s and what have ya
wen finished unplug it
it will say if not switched off creat list yes or no hit yes and bamm bingo it works
p.s. this did work for me and i am i have an iq less than 60
Posted on Jan 25, 2009
  • 4 Answers
I managed to fix this,
on the MP3Player there is a file created when you sync it with mpmanager,
this file tells the MP3Player where the songs and directory's are,
without the file DIR Navigation wont work as its reads this file
bottom line:
Use MPManager, dont drag + drop.
Posted on Jan 24, 2009
When selecting the DIR navigation option, tap the select (M) button very quickly. It will skip to a hierarchical view of your directories.
If you install the software that comes with unit, you will be able to donwload the manual.
Posted on Dec 29, 2008
NTLDR is missing
Try copying this same file from another working computer (same OS version, same folder). Search the root directory for hidden files (on command prompt, use commands DIR /A to list files, ATTRIB -H to show hidden files, and COPY.
Dec 22, 2013 | Computers & Internet
HOW DO I UPLOAD MUSIC TO MY MP3 PLAYER
Hello Elizabeth,
To transfer music to your player, connect your Coby MP600 to your computer using the supplied USB cable.
Once connected, your computer will automatically recognize the player as a Removable Disk.
??To open the player to view files, double-click the icon that appears.
Once you have opened the player's folder, simply drag and drop files to the player as you would a floppy disk.
??Copy music files to the root directory.
??Copy movie files to the "MOVIE.DIR" folder
??Copy photo files to the "PHOTO.DIR" folder
??Copy text files to the "TEXT.DIR" folder.
After copying the files, disconnect it properly and you are done.
I hope this helped you.
You can rate my answer if you appreciate my help.
Thanks!
Oct 19, 2011 | Coby MP600 Digital Media Player
How to install java games (.jar , .jad files available in my pc) in my samsung SGH-F400
hi, you have to coppy the jar file into the install folder on your phone and make sure the java version of your phone is compatible with java file. then install from the folder.
May 27, 2010 | Samsung SGH-F400 Cellular Phone
What are 3 functions of syntax in command 'dir'
The syntax is the correct method of typing a command. The command must be entered in the correct order and spelling for the operating system to accept it. So : dir/w is correct But dir \w Is not..
dir/w will display the contents of the current directory, but in a wide format dir/p will display the contents of the current directory until your screen is full. You then press any key to scroll down the directory listing until you reach the end. dir will display the contents of the current directory with each directory item shown on a new line. you can use each of these switches together too.
dir/w/p will display the contents of the current directory in a wide format but the listing will pause when the screen is full. Pressing any key will scroll the listing down. A word to the wise. If you are not comfortable or have little or no experience with working in the DOS Command environment, DONT.... You can cause serious damage to a system simply by mistyping a command or using the wrong command. Do so at your own risk..
Feb 05, 2010 | Gateway GT5220 PC Desktop
Empty Disk
SAME THING HAPPENED ON MY MP3 I FORMATTED IT BUT IT WONT PLAY SONGS TRY FORMATTTIN IT USING WINDOW
Sep 30, 2009 | MPMan MP-F40 MP3 Player
Error 0x80070091 the directory is not empty
There is most likely a hidden or read only file located in this dir. Have you tried to view the hidden files?
Jun 11, 2009 | Microsoft Windows Vista Home Premium for...
Dos commands in linux
go to http://www.pctechguide.com/articles/gettingDedicated12.htm you will find all the commands you need in there.
Jun 01, 2009 | Microsoft Computers & Internet
Downloaded pics from blackberry using USB
What has happened is you had the Encryption mode turned on. You need to click on Options-Media Card- and turn encryption off then go into Options-Security Options-and disable content protection. After that follow this guide below to fix the other ones.
  1. Turn off future encryptions
    • Go to Options -> Media Card
    • Set Encrypt Media Files to No
    • Note: Despite what people say, you do not have to set Encryption Mode to None - this has nothing to do with your encrypted media files
  2. Move the encrypted files in order to decrypt them
    • Go to Media
    • Press the Menu key
    • Select Explore
    • Navigate to the directory containing your encrypted files
    • Create a temporary folder
    • Move the encrypted files into the temporary folder
    • Note: If you have media files in other directories that need to be decrypted, don't put them in this temporary folder. Instead, create a separate temporary folder in that directory and repeat these steps. This way, you can remember the files' original location
    • For impatient people (like me) or people with way too many encrypted files: To quickly decrypt files:
      • Move one file into the temporary folder using any method (this lets the BB remember the temporary folder as the folder you will be moving future files into)
      • Scroll to the next file
      • Press the M key (this highlights Move)
      • Click the trackball
      • Press the M key (this highlights Move here)
      • Rinse & repeat
  3. Clean up
    • Technically, you could use the BB interface to clean up, but if you have way too many files, you'll want to use the Mass Storage Mode - this is more efficient, allows you to navigate the directories quickly, and allows your files to move to their original directories quickly
    • Use the USB cord to connect your BB to a computer and enable Mass Storage Mode
    • Navigate to the temporary folders
    • Move the containing files to their original directories
    • Delete the temporary folders
Jan 21, 2009 | AT&T Blackberry Curve 8300 Smartphone
Cannot Navigate By Folder on MP3 Player
The manual will give you a detailed schematic of the menu option that allows you you to go from repeat to shuffle, etc.
Dec 23, 2008 | Nextar MA570 MP3 Player
QUEST SQL Navigator 3.2 with Oracle 10g Fails
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Dec 21, 2006 | Quest Software SQL Navigator Professional...
1,617 people viewed this question
 Grubhead
Grubhead
