Question about JVC Audio Players & Recorders
My shelf system says protect when i turn it on & i don't know if thier's a way to reset it. model#ca-mxgc5
    President:
  • 624 Answers
The only way to reset these units is to unplug it from the wall for about 4 to 7 days, then plug it back in and see what happens. They do not have a reset button, and it takes a while to reset because they have a capacitor in the microprocessor circuit that holds the voltage for it for a good long while. The type of capacitor they use acts much like a battery and takes a long time to drain.
Your unit is in the protect mode, and it happens when there is a blown channel in the amplifier circuit or a power supply failure. The only way to determain exactly what is wrong would be to troubleshoot the unit using the proper tools. If you have a multimeter and soldering equipment you may be able to do this yourself if you have some experience with electronics. If you do not, you really should just take it in for repair at an authorized JVC service center. They would have the schematics and ability to troubleshoot it properly.
If you have the tools needed and would like to try it yourself just let me know and I will be happy to guide you thru the process. Please be aware that troubleshooting electronics by somebody with little or no experience with it can often result in more damage than you started out with in the first place. Having said that, if you are willing to try, I am willing to help. But if you end up with more damage than you started with you can not hold me responsible, I have warned you
I work at an authorized JVC repair center and have repaired many of these units over the years, so you would not be getting help from somebody who doesn't know what they are talking about. So just let me know if you want to take a crack at it.
Dave
Posted on Oct 28, 2008
My JVC stereo receiver CA-HXC6, how do i get itout of protect mode? it turns on then goes right to protected and turns off
google stk428-610 ic an stk428-640 ic an replace them , they have to be solder in , don't try this if u don't have experience
Sep 09, 2010 | JVC HX-C6 Shelf System
My JVC mx-gc5 stereo says protect and then shuts off
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
Dec 12, 2009 | JVC MX-GC5 CD Shelf System
Jvc model no.ca-hxd7 system no. hx-d7
Check back speaker wires! this is protection mode! There is a short circut! look for stray wires touching metal or each other!
if this does not do it then unit will have to be fixed by a pro!
Please use the ratings and help keep this area FREE!
Jan 23, 2009 | JVC MX-GT88 CD Shelf System
I TURN MY STEREO ON AND A MESSAGE APPEARS ON THE SCREEN THAT SAYS "PROTECT" AND IT POWERS DOWN. JVC MODEL NO. CA-HXD7 SYSTEM NO. HX-D7
OK this is the protection mode! There is a short circut! unplug and check all back speaker connections making sure no stray wires are touching metal or each other ! if this does not help the short is inside of unit and will have to be fixed by a pro!Please rate my answer and help keep this area FREE! THANK YOU!
Protect push power
yea i have the same problem. i dont know but i think maybe the amp brd is faulty.
joe.
Apr 22, 2008 | Sony MHC-GS100 CD Shelf System
Protecked mode?!
when i had this problem my wires were touching the case. other times the wires were touching eachother
Mar 23, 2008 | JVC MX-KB30 CD Shelf System
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
PROTECT MESSAGE
Most likely he has a couple of the connectors crossed. It is going in protect mode to keep it from damaging the internal electronics. Open it back up and double check all connections. then let me know.
Jan 07, 2008 | JVC HX-D7 Shelf System
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
153 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
