Question about GE Spectra JBP78 Electric Kitchen Range
Element replacement I replaced the upper heating element exactly as I removed the old one. However, when I kicked the breaker back on, the element starting heating even though the control was in the off position. Any ideas on why this is happening?
  • 1,543 Answers
Sorry, but that's a bad one. If you have a JBP78 as you posted under, the broil heat relay contacts arched and welded closed. = replace electronic range control. If you do not have that model, you may have a separate bake / broil switch, which is where that problem occurred and then that would be able to be replaced.
Posted on Oct 28, 2008
Water heater is kicking switch in upper unit
typically when the upper braker pops in an electric water heater, it is an indication that the upper element has been breached, allowing water into it and shorting out the unit. the breaker prevents electrical disaster.
turn off the power to the unit via the breaker box, remove one power lead from the upper element, and with a multimeter, make a resistance check. Should read somewhere close to 14 ohms. If you get a significantly higher reading or significantly lower reading, the element is bad and needs to be replaced.
To replace the element you will need a socket wrench that fits the element. prepare your replacement assembly by seating the seal to the base of the element. Ensure the power is off, remove the second wire from the element, shut off the water supply valve, check that the pressure is off by turning on a hot water faucet near the unit and shut it off when the water stops running.
Be prepared to move quickly as water will come from the heater when you remove the old element, but not so much if you are ready for it. I typically lose less than 2 cups of water changing elements. Unscrew the old element pull it out and immediately insert and begin threading the replacement. tighten it until no water can be seen seeping past the seal.
SLOWLY open the water supply valve, sudden pressurization can cause other plumbing issues. When you hear the water stop running, check your new element for water seepage, tighten if necessary. Dry the area and reconnect the wires to the element.
now reset the power breaker. Some noise is to be expected as the elements heat the water to normal operating temperature, run a nearby faucet, hot side, to purge and air from the system.
You should be good to go.
REMEMBER: Power off FIRST, then water... do repairs... water on...SLOWLY.... Power on LAST. Stay safe out there
Mar 04, 2015 | Water Water Heaters
My water is not heating in my Rheem 40 gallon electric. I pushed the reset button, but when I turn off the breaker and then on again, I do not hear the elements heating up.
Electric water heater can be repaired by homeowner
If I understand correctly, water heater is producing no hot water.
Reset button clicks in, but still no heat.
Three initial things can be causing this:
1) No power to water heater. Test across top two screws on upper thermostat for 240V. Red and black wire are attached to these screws. Screws are marked 1 and 3. Upper thermostat is same that has reset button. If power tests 120 across screws, then breaker may be off on one leg. If no power, then start testing at breaker.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Upper thermostat is bad. Replace thermostat with generic upper thermostat available at hardware store.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Upper element is bad. Test and replace element using Rheem 4500 watt element available at hardware store. Image shown below. Look at label on side of tank for element wattage. Rheem puts 4500 watt elements into all their 240V electric water heaters.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If upper element is burned out the tank will not heat any water.
http://waterheatertimer.org/How-it-works.html
Rheem 4500Watt element
Upper thermostats are generic and interchangeable:
Nov 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
4) Bad upper element. Test upper element.
Nov 22, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Red reset button keeps kicking out, i reset button and works fine for a day or two then kicks out again
The reset button kicks out because the thermostat detects overheating.
Anything over 150 degrees, the reset kicks out.
This is caused by 4 things.
1) Bad upper or lower thermostat. Thermostat sticking in 'on' position and elements overheating water.
2) Factory-installed insulation and cover are removed
3) Bad element shorted to ground at center of element, and element continues heating with 120V through the ground wire.
4) Loose wire near upper thermostat, that is shorting and causing heat.
Solution:
Check for missing insulation.
Check for loose and burned wires.
Replace both upper and lower thermostat.
If problems continue, test water heater elements and replace bad element.
If you need more help, add a comment and I will respond.
Oct 29, 2010 | Reliance & 40 Gal Electric Mobile Home...
Kenmore Elite electric dryer-65942401 and it runs but does not heat. I have heard that best thing to do is replace heating element, but is there anything else that needs replacing along w/it, and we can't...
You need to check the breaker, often the heat 1/2 of the 220 volt breaker trips and is not visually obvious. Best to know so check with a volt meter, or forceably turn off the breaker, FULLY off, press hard, and then back on and test again. If it keeps happening, you may need to have an electrition investigate.
There is very little failure of heating elements, but not unheard of. More common is a bra wire shorts the element. remove it and often you are good to go, but sometimes it burns through.
Oct 13, 2010 | Kenmore 65942 Electric Dryer
No hot water
Check your panel breaker to make sure its on. If it is, it's possible that the upper thermostat or element has burned out in your heater.
First remove the upper thermostat cover plate and check the high limit switch button. If it has tripped, press it to reset it.
Check for power at the input terminals of the upper thermostat. (usually marked L2 and L2) If no power is present then check your circuit breakers or wiring to the water heater.
If there is no hot water then the upper thermostat should be applying power to the upper heating element. Check for voltage at the upper heating element. If there is power at the heating element but the element is not getting hot then the heating element needs to be replaced.
If there is no power at the upper heating element then the upper thermostat needs to be replaced.
Hope this helps.
Mar 14, 2010 | Welding Tools
The bottom heating element won't heat up
If the new element is good then the next thing to check is the selector knob (COOK/BROIL) and the thermostat for the oven.
To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
There is a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Oct 28, 2009 | Ovens
No heat at all.
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 26, 2009 | Roper REX3614KW Electric Dryer
No hot water
If the water does not heat, then you have to troubleshoot to find the problem. With a voltmeter determine if 240VAC is actually getting to the water heater. Take care here - a defective circuit breaker can give a false 240 volt reading - check for the 240 volts across the upper element (i.e. when the 240 volts has a live load on it, not just an open circuit test).
Also, remember, the upper element has priority over the lower element, and if the water is cold, the upper element will try to turn on and this locks out the lower element (only one element is allowed to heat at any given time). The lower element comes on ONLY after the upper thermostat is satisfied. Therefore if the upper heating element is burned out you will never get any hot water. If you suspect this, TURN OFF THE POWER TO THE HEATER and take a resistance check of the upper element.
Nov 15, 2008 | Water Heaters
Won't heat!!!
First, are the burners working right? It is possible that a breaker opened. Cycle your breakers off and then on. Its a shot....
How many elements in your oven? Sounds like one fried. Start the unit with the door open. See which element doesn't glow after a few minutes. Wait for cooldown, open the breakers and then remove it and take it to the appliance repair parts guy to test and replace. Funny...you should have gotten an error code.
Not that? It will likely be the thermister controlling your temp sense.
Dec 21, 2007 | GE Profile JT955SFSS Electric Double Oven
GE Spectra JBP78 Electric Kitchen Range Logo
140 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
