Question about Akai PDP4290 42 in. EDTV-Ready Plasma Television
Verticle Green Lines Appear On Akai Plasma TV Model PDP4290
Original Post Under Different Topical Heading/Caption I have a similar, but different problem, than the one described under this heading. I own a AKAI 42 in. Plasma Television (Model PDP4290) that is three (3) years old (purchased Nov. 2003). The screen produces about twenty (20) green lines on the left side (while facing screen) when the background image is other than blue. I have a DVD player plugged in as component 1, and cable television signal running through a VCR which is then plugged into the video in plug. The green lines appear when receiving signal from either source (i.e., cable, VCR or DVD). Any suggestions?
4 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Akai PDP4290
yes you it is fixable you are having a micro chip problem or a power supply problem. take it to a tech.to have it repair.
Posted on Feb 25, 2007
  • 8 Answers
SOURCE: Akai 42 inch plasma
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Posted on Jul 12, 2008
SOURCE: Green reflections on our 42 inch akai plasma
REMOVE THE GROUND FROM THE PLUG, I DID THIS AND MY TV'S ALL WORK A LOT BETTER. GOOD LUCK AND PLEASE LET ME KNOW IF THIS WORK. PS IT IS SO SAFE TO DO THIS. WONT HURT ANYTHING.
Posted on Feb 21, 2009
Sanyo TV model T27547 has horizontal lines across the top of the screen in front of what is being showed on tv. Is the tv worth trying to fix the picture is still very good.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 02, 2017 | Sanyo Televison & Video
I need to know what input & output connections are available on the Akai PDP4290 Plasma TV?
This was the cheapest Akai in its day. No Tuner, No Speakers, must use a surround sound or regular stereo amp for sound.
It also has the standard A/V input also.
Best to use a HD Box and RGB cables for best picture.
Dec 04, 2010 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Akai
hi there,
you must told to your hubby to check for the continuity on the main power supply of the unit, there's a part that need to be Replaced Small Electros In Main Power Supply.
let me know.
Oct 05, 2008 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Akai 4290 power board
Yes, I'm sure the board is bad. I had the TV checked out by a local TV repair shop. I also opened the thing up to see if I could do anything with it and it's obvious that this is the board that has bitten the dust. The correct number for the board is AA98-00188A. I made a typo in the first post.
Jul 30, 2008 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Akai PDP4290
Feb 09, 2007 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Akai blackline near bottom
CALL LARRY AT 251-479-3567 HE HELPED ME WHEN AKAI WOULD NOT.
Jan 08, 2007 | Akai PDP4290 42 in. EDTV-Ready Plasma...
AKAI PDP4290
you need to check the screen voltages inside the unit is a sticker with the voltages on it, if all the voltages are normal, could be the panel is bad, if the voltages are low or nonexistant it could be the L-main,Main or Y-main board
Oct 13, 2006 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Similar Problem with Verticle Lines
sounds like a loose cable inside the set, if not it looks like a logic main board
Sep 04, 2006 | Samsung LTN1535 15 in. HD-Ready LCD...
Akai PDP4290 42 in. EDTV-Ready Plasma Television Logo
174 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
