Question about Garden
Pops back through carb
Toro model 38116 when cranking pops back through carb. I thought it might have a broken reed valve, but my inspection showed no reed valve in this engine. Can you help?
  • 48 Answers
Sounds like a sheared or partly sheared flywheel key -
Posted on Oct 29, 2008
Does a ***** boy 50cc have a reed valve? Bike
Hi first thing what is the bike second thing is the engine a 2 stroke, if it is 2 stroke it most prob. has a reed valve, check that the carb needle valve is working as it should, then drain the cylinder and crank of fuel check the plug sparks, leave the carb off and put a small amount of petrol in it, try and start it if it fires once or twice, then it should start with the carb on it, if not there is a problem with the carb. good luck.
Sep 12, 2014 | Motorcycles
Why does my 800 sxr jet ski engine runs full throttle and keeps running even after I pulled the spark plug caps?
dirty carbs !
reeds broken will spit back through the carbs !
crank seals worn can let engine run away !
Jul 07, 2014 | Boating
1996 Yamaha 150 oily plugs, air blowback in lower
Check reed valves aren't brocken
Aug 08, 2013 | Boating
2003 kx250 why my reed petals keep going bad?
A reed valve in a 2 stroke engine is basically a way to prevent the fuel/air mixture from being blown back into the carb. If yours keep failing, the most likely reason is that you have bought cheap reeds. There should also be a reed valve support on the carb side. this is to stop the valve from vibrating and bending the wrong way.
Apr 24, 2013 | Motorcycles
Air compressor model no. 921.153101 blowing air trough air cleaner
If you get air movement out of the air cleaner and it only compresses air to 25psi, you have bent or broken reed valves in the head. Take the head off the cylinder and inspect the valve plates and reed valves. This is a Craftsman compressor so you'll most likely have to get parts through Sears at www.searspartsdirect.com. For best results replace everything between the head and cylinder; gaskets, valve plates and reed valves.
Oct 03, 2012 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
If i fliped my jey ski the wrong way how do i fix it?
If you have a water drain knob for draining the crankcase (Kawasaki 2 stroke motor) ,pull the knob and drain the water. As long as you have not turned the motor over you are OK. Get the motor started and run it long enough to dry it out. If you filled the motor with water, turned it over and now it wont run, you probably have broken the reed valves. You will have to pull the carburetor, check the reed valves, and dry out the motor as quickly as possible. Be sure to fog the lower end as quickly as possible so the crank bearings and piston needle bearings do not rust. Replace the broken reeds, put the carb back on, and you should be back in business.
Aug 12, 2010 | Electric Eyeware Radio Control Electric...
Air pressure iI gone but motor works haappened all
As I understand it, your air compressor motor runs but you can not build pressure. Is this correct?
Two main reasons:
#1: Your safety valve popped and the air is going straight out the safety valve. You should be hearing a loud hissing noise if this is the case. Press the safety valve back in and you should build pressure. Many such valves have a ring on them (to help you find them). It should be very near the pressure switch.
#2: You have a broken reed valve. A reed valve opens or closes based on the pressure it is under. It allows air to enter the tank on the compression stroke, but will not let it out of the tank as the piston strokes up and down. If it is broken or stuck open, you cannot build pressure.
and #3, a after thought, no extra charge ;-) The rings on the piston may have broken.
For #2 and #3, it will be necessary for you to remove the head to inspect.
Find repair parts at the Coleman web site.
I hope this helps you solve your trouble.
Thanks for your question at FixYa.com
If you found this helpful, please vote.
Thanks
Dec 24, 2009 | Coleman Powermate 4 Gallon Air Compressor
1999 rm250 won't stay running seems to flood itself????
First I think you paid too much if it won't run. The problems to look for are possible air leak from bad crank seals or blown out / broken cylinder base gasket or maybe a cracked carb spigot and if it has reed valves, maybe a broken reed. Also check the compression, it may have seized at some time and stuck or broke the piston ring.
TOK
Aug 27, 2009 | 1998 Saturn SL
Kx 125 reed valves
The reed valve assembly should hold solvent withot leaking. Remove for test. Disassemble and clean reeds and reed seat. Perfect seal is very important.
Good luck,
Techjoel
May 17, 2009 | 2003 kawasaki KX 125
Garden Logo
287 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
