Question about LaCie (300770) 250 GB Hard Drive
Upgrade Possible? I have a LaCie 300770 250GB Hard Drive Triple Interface. Drive is 3 years old and running out of space and out of warranty. Can the internal disk be replaced with a 1 TB drive? What type of drive is installed in this unit (IDE, SCSI, SATA)? Will the **** controller work with a larger capacity drive? Thanks, Al
  • ahoover Mar 20, 2009
    OK posting for others benefit! I just upgrade the following LaCie Drives.
    LaCie d2 HARD DRIVE Extreme 250GB Model 300770. Original internal drive Maxtor MaxLine Plus II 250GB ATA/133 HD replaced with WD5000JB-RTL 500GB EIDE. Configured as single master. Worked and formatted.
    LaCie d2 BIG DISK EXTREME 500GB Model 300794U. Original internal drives Qty 2 - WD2500JB-00REA0 250GB ATA/100 HD replaced with Qty 2 WD5000JB-RTL 500GB EIDE. Configured one as Master with Slave and the other as Slave. Worked and formatted 931.2GB logical RAID 0 drive.
    Hope this helps the next guy/gal!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 59 Answers
Hey Al,
The internal Drive is a standard 3.5 inch IDE 7200RPM unit. you can indeed upgrade this to a 1TB drive as long as it's IDE wether 2.5 or 3.5. Luckily when Lacie was originally offering these drives you could get these in 1TB, so that won't be an issue.
Ciza
Posted on Oct 29, 2008
Error 252 lacie disk
Is your drive Old , and has been travelling a lot, could have been hampered, or the connecting cable corrupted, try another cable, or keeping hardrive in various different positions and working e.g upside down, sideways, If it does not work, you need a new one, back up whatever data you can.
Dec 10, 2013 | LaCie Big Disk Extreme with Triple...
I have an old LaCie d2 160GB Hard Drive Extreme with Triple Interface (circa 2005)... I have lost my power cord and I can't seem to be able to find one online to purchase...Does anyone know where I can...
your drive can be used with any D2 or Big Disk power supply as well as some LaCie Porsche power supplies (you need to make sure the connector is the same).
Searching for LaCie Power supply on eBay will give you a few hits that match your needs.
Regards,
Jan 10, 2011 | LaCie (300740) 160 GB Hard Drive
I had 4 LaCie 2TB Big Disk Quadra, Item 301343U. They are connected to a Nitro 8-PORT FIREWIRE 800/1394B PROFESSIONAL (N8PFW8HR) hub. The hub is connected to a LaCie Firewire 800 PCI card. I am running...
Let's not take this as a solution so much as an intuition. I believe you may have run up against a limit of physical disk space that XP can administrate.
DO me a favor and don't give my rating a thrashing if I'm wrong.
Best Regards,
Marcus
Sep 23, 2010 | LaCie Big Disk Extreme with Triple...
Lights on nobody home
Well if it is less than 2 or 3 years old you could contact them to attempt a sawp out of the drive. Over that - replace the unit. IF you do - you might want to consider a duel disk enclosure so if a drive dies, your data does not. you can build one yourself (1 TB duel drives, Raid 1) for a total of 252 bucks, with good drives (Seagate - Barracuda) Yes I swear by the Seagate Drive. For off teh shelf they have worked very well in every application I have deployed them.
I've been burned by too many single drive failures - even when I have the data backed up it is still a royal pain.
Jan 25, 2010 | LaCie Big Disk Extreme with Triple...
My LaCie 1T Big Disk Extreme just keeps clicking....
No do not throw it away buy another enclosure for it and take the driveout and put it into another enclosure you will have better results and a longer lasting drive and you be glad you did!
Jul 19, 2009 | LaCie Big Disk Extreme with Triple...
LACIE drive not visible
Unfortunatley this is the classic symptoms of a broken drive. You can try accessing the drive on DOS by using online software. (eg spinrite).
If you get your drive to work copy all the important info onto discs and format this drive.
As i repair PC's this is the most common problem. Hard drives are only guaranteed for 1 to 3 years.
To help you in future
*Defrag your hard drive every month
*Backup and format the drive every year
*And never fill up a drive over 60% ( eg never exceed 60 gig on a 100 gig drive.
These easy steps should stop a hard drive faliure and make it last around 5-10 years.
Hope this helps
Jul 18, 2009 | LaCie Big Disk Extreme with Triple...
Hard drive will not come on screen
Usually this is caused by a bad power supply on the drive. Do you have another one that you can try? I think LaCie will send you a new one for less than $20 if it's out of warranty.
Apr 05, 2009 | LaCie Big Disk Extreme with Triple...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
LaCie (300770) 250 GB Hard Drive Logo
282 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
