Mitsubishi CS-31303 will not power on.
The TV was turned on when connected to a small UPS unit which power was most depleted. When powered on while still connected to the depleted UPS, the TV united sounded as if there was some type of power surge and did not power on. Now when power button is depressed on the unit or the remote, the unit sounds as if it will turn on. There is a a high pitch sound and turns back off without picture or sound. The fuses are okay. Do you have any idea on what to address here?
I have Mitsubishi TV CS-31303. It has transient issues. At turn on, it shows horizontal fringes for some time along with picture, then single horizontal line only and then after some time finges at the 1/3rd bottom and then clear full picture. After some more time the clear picture turns into horizontal fringes at the bottom 3rd of the picture and picture rolls and then again the picture is very clear. Some one said that there is an issue in the signal PCB. Where is it and what componets are at fault. I do have service manual which shows circuit diagrams.
Posted on Sep 29, 2010
I have a Tripp-Lite 1000 Lcdf, surge protector, that keeps my TV and Stero on ofter you lose power. The unit wasn't working. I tried to push the power button, and there is no power to the plugs
Hi Richard,
Sounds like the you will need to replace the battery in the UPS. When the batteries are completely depleted the UPS will not turn on.
If you need UPS, Surge, or Power Related help contact:
Inside Service Sales
Daniel Salazar 800.260.2259 daniel@psihq.com
Power & Systems Innovations, Inc.
customerservice@psihq.com
Power & Systems Innovations, Inc. is an Elite Certified Service
Sales Partner for APC/MGE brands manufactured by Schneider Electric
Visit us at www.psihq.com
Apr 18, 2014 | Tripp Lite Computers & Internet
Schematics cs 40505
Alas, your great TV has had a power supply failure.
Mar 10, 2014 | Mitsubishi Televison & Video
What is the code to unlock my mitsubishi CS-31303 tv?
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
Jun 25, 2012 | Mitsubishi Televison & Video
When connected to power the green light is not showing and the battery light is is always on
This indicates the battery is worn out and will not provide power in the event of a mains power failure.
To test the battery, connect a computer or some other device to the output on the UPS, and connect the UPS to the mains supply. Turn on the mains power to the UPS and power up the computer, then turn off the main power to the UPS and if the computer switch off in a short time.
This proves the battery is old and needs to be replaced.
Mar 19, 2011 | APC APS BackUPS CS 650VA 400W 230V DB9...
Television is dead. won't turn on picture or
There is a fuse in tvs I've had to change one myself
Oct 16, 2009 | Mitsubishi CS-26201 TV
The battery backup side of the APC does not work how can I fix this?
How old is unit? UPS is a Battery that is charged from power outlet.It maintains voltage when computers are plug into it so fluctuations in current don't spike or wane.On a Power Failure the UPS supplies all the power by using the battery and an inverter.If your units batteries are not charging you need to replace them.In most cases it is not cost effective.Do some more test before you replace it.Good Luck.
Sep 08, 2009 | APC Back-UPSĀ® CS 500 UPS System
Television shuts off by itself/ no picture.
bad regulator or high voltage circuit. also some newer sets will shut down if the vertical drive ic blows,because damage to the tube will result from a horizontal line.
May 16, 2009 | Televison & Video
Ups is not glow any indication, just give buzzer sound , APC make 2000va RS model kindly tell me what i can do to repair it.
It look like dead battery. Try to connect carefully new (or allmost new) battery with 24v lamp in (+) wire. If UPS alive - you'll see only small momentary sparcle. After this - connect battery as usual and try to turn system on. Be carefull! If lamp lit in full power - it means a serious internal problem. Best solution - look for qualified serviceman. (maybe yoir system needs reprpogramming).
Apr 13, 2009 | APC Back-UPSĀ® CS 500 UPS System
UPS is not showing AC light on i.e Green light
It does not look good for this unit.
Time to upgrade, go bigger. Maybe this unit is too small for you system. Most likely a 1000VA will solve your problem.
Sep 10, 2008 | APC Back-UPS CS 500VA UPS System
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
