Question about Honeywell Heating & Cooling
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and the room may be 21 deg for example, but still the flame icon appears on the lcd screen of the thermostat and the radiators are luke warm continuously. Once the time reaches a preset the boiler kicks in fully to give proper heating and the radiators become very hot. Any help to allow the thermostat to be left in AUTO without the continuing operation of the boiler out of any time settings would be appreciated. Regards Barry.
  • 2,290 Answers
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Posted on Apr 10, 2017
The HVAC Guy
  • 30 Answers
SOURCE: Goodman GSH130301AB heat pump with
the reversing valve wire needs to be on the o terminal.nothing will be on the b terminal on the thermostat
Posted on Oct 30, 2008
  • 67 Answers
SOURCE: hitachi
I would really call your installers back mate.
If you have anything to measure air temp with I will take you though some tests.
But at this point I would say that your air con does not have any gas and the installers should come back. If they will not come back you should contact Hitachi warranty
Hope this helps
Posted on Jan 11, 2009
  • 700 Answers
SOURCE: My outdoor heat will not
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Posted on Jan 25, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Heat/Cool model AJHS10DCBM1
OK I will be looking over the manual. Now that squeal sounds like the squirrel cage fan scraping the housing around it. Those units are so tight fit they can be twisted one way or tightened a little to much they scrape. I love them for there silence win they work right but hate them because my hand are too big to move things around inside them. Stay in touch I will be looking around while
multi-tasking today- I'll be here!
Posted on Feb 02, 2009
  • 478 Answers
SOURCE: Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Posted on Mar 11, 2009
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
New sime e comfort 25HE boiler problems
It not wired in right that why its coming on when it is off The boiler is over riding the programmer when it is off .
The boiler should call for heat if programme is on it sounds like boiler is wired into the 24hr mode or over ride mode that why it is coming on . google wiring for y plan heating system. this will help you fault find on this . changing vales and thermostats will not help you . Hope this helps .
Mar 05, 2017 | Water Heaters
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Require room thermostat for ferroli combi boiler optimax 25c . I have a honeywell at the moment which stopped working. it has two wires coming into it from the boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
Alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Jan 05, 2009 | Water Heaters
I found this on a search:
"I have the full set of instructions, contact me at
Not a very reliable system, transmitter keeps resetting to 17:25; locks up. Whole system then requires setting up from scratch. Had a replacement transmitter, no change, and same faults.
Perhaps this can help.
Mar 15, 2008 | Computers & Internet
Heating & Cooling Logo
63 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
