Question about Toshiba 42H81 42" Rear Projection Television
Pic bad i have a toshbia 42h81 rear proj tv pic cuts out can see it but waves make it hard and the sound cuts off and on? any help
  • zap3003 Nov 11, 2008
    hi i am having the same problem, i am familiar with electronics but a step by step would be great help for me on how to fix or change the hyper unit. thanks for any help you can give me.
    my email is zap3003@charter.net
    plz send help
  • 934 Answers
Repair the hyper module.... See some of the previous posts for this problem...
Bill
Posted on Nov 07, 2008
I have no pic sony lcd proj tv model # kdf-55wf655, 57in,
Lamp or ballast bad. If ballast good and lamp bad, will here a mosquito buzz every 15 secs. after turn on.
Apr 20, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Only sound no pic turns on off by self now and
When convergence amplifiers blow TV will not turn on and also usually needs new micro fuses 4-6 of these as well as the convergence amps. Lots of meter checks and soldering
Dec 15, 2009 | Toshiba 42H81 42" Rear Projection...
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
Tv picture is shakey
Bad capacitors on Hyper module = no longer available, but
can be rebuilt by PTS Corp or a qualified tech...........T.
Feb 13, 2008 | Toshiba 42H81 42" Rear Projection...
No image on my TV
Bad hyper module = no longer available = have qualified tech
rebuild yours = replace bad caps on board...............T.
Dec 08, 2007 | Toshiba 42H81 42" Rear Projection...
Sond no picture
try this
sounds like the teletext module's
http://forum.eserviceinfo.com/viewtopic.php?p=4626
Dec 07, 2007 | Toshiba 42H81 42" Rear Projection...
Phillips Proj TV 9P5034c101
call tech..converge eprom has to be changed from old to new board.
Nov 16, 2007 | Sony KP-53V75 53" Rear Projection...
42h81 RPTV
Rebuild hyper board = replace bad caps on board................T.
Nov 04, 2007 | Toshiba 42H81 42" Rear Projection...
42H81 touch focus error
check for bad solder connections on the connvergence ics if that dont fix it then replace them
Nov 01, 2007 | Toshiba 42H81 42" Rear Projection...
Toshbia Projection 50''
A few problems come to mind. The high voltage block took a dump and opened up. The filiment supply from the HV sweep has cold solder connections on the Printed circuit board. Another problem is the most common of all could be a vertical sweep falure like the vertical output IC or the b+ going to the chip or maybe even a bad yolk connection on the solder side. Good luck
Apr 28, 2006 | RCA P61830BL 61" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
