Question about NetGear DG834G Router
Have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
Hi
I have a new lap top and can't connect to my Netgear DG834G router wirelessly as it is security enabled and i can't find or remember the security code.
please can you help
regards Paul
I have my router set up it is working fine but it is unsecure none of the password work i want to set it up with a secure password so that no one else can log on to my router can you please help me to do this
thank you
Posted on Nov 03, 2008
  • 68 Answers
Paul.
Can you connect to the router via ethernet?
If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
If you need the manuals you can download from here.
http://kbserver.netgear.com/products/DG834G.asp
Regards
Nick
Posted on Oct 29, 2008
How do i secure wireless net work its shows local only
Hi if it shows local only means you not connected to the internet and only you can access your network make sure you apply wireless password to make your network secure check the WAN cable which directly connect to your NetGear DG834G Router you can disconnect that directly connected to your laptop and see if you can access the internet should you need any other help please contact me on my weblog http://computernetworksupportindubai.com/
Jul 22, 2011 | NetGear DG834G Router
At work we have a LAN connection, can a Netgear 834g router be used as a wireless access point by plugging the LAN into one of the ports, (using it as a port switch?)
yes you can use as a wireless access point by plugging lan cable in to the yellow coloured port on your netgear not any of ports, have a good day....
Feb 01, 2011 | NetGear DG834G Router
I cannot get wirelessconect to my laptop from my netgear modem router DG834G.I can see the signal but unable to connect
check whether the dhcp option is turned on in ur wireless router. if its turned off, change it to on state and try. u will be able to connect. still if u din get access. use some other lap to connect to ur wireless network. if it is possible to connect with someother lap, then the problem is with ur lap. the wifi drivers might get corrupted. re-install it to fix the problems. if all above doesn't gets work, then the problem is with ur wireless router.
Jul 21, 2010 | NetGear DG834G Router
Have lost the the security code they gave us when the router was changed. how do we find it or change it. the router is netgear DG834G it won`t let us log on any more lap top without the code
Before resetting the router, please try the user name 'admin' with the password 'password' or '1234'. These are the default user name and passwords for Netgear routers. If neither of these work, there is a small black button on the back of the router with 'Reset' written by it. Press this down and hold it for approximately 40 seconds, or until you see the lights blink on the front. Now you can access the router via your web browser using the default settings. All settings will need to be reinserted into the router. I will post a How-To on how to do that today.
Good Luck,
NOLA Tech
Jan 27, 2010 | NetGear WGR614 Wireless Router
Connecting lap top
If this is a new router you will find everything you need in the router's manual. You will need that to set up the WEP key. If the router has been used wirelessly before, then you will need the WEP key to set up the connection through the windows wireless connection wizard. If you don't know the WEP key, you will have to connect to the router with a cat-5 cable and access the router that way with your internet browser to find the WEP key, or generate a new one. You'll need to type in the router's IP address in the address bar of the browser.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 26, 2008 | NetGear DG834G Router
Connect netgear DG834GT to laptop - says limited connectivity
how do i connect the netgear dg834gt to my computer please help
Jun 29, 2008 | NetGear DG834G Router
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
NETGEAR DG 834G ROUTER
Could you give me some overview of the topology of the network your trying to install the router on? (How it's all connected, and the ip addresses of the machines and other routers on the network (if any)) ?
Nov 29, 2007 | NetGear DG834G Router
Connecting two laptops using Netgear 834G
If its just a router and not a modem router, go into the routers settings and make sure DHCP is enabled to give each pc an automatic IP address and ensure wireless is enabled if using wireless adapters. Next go to the properties of your network card and on the TCP/IP select properties and ensure obtain IP address automatically is ticked. You must also set up using the XP network wizard and ensure file and printer sharing is set up through both pc's.
Feb 07, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
220 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
