Question about Maytag MZD2768G Side by Side Refrigerator
Refrigerator won't cool. Freezer works fine!
Freezer side operates properly: holds temperature, etc. Refrigerator side won't go below 50 degrees F, even when set to coldest setting. Meat storage drawer shows aboout 50. We've emptied refrigerator side, and don't see any blockage. Don't both freezer and refrigerator opeerate on same refrigeration compressor and coolant? Thannks for your help
  • 1 more comment
  • Anonymous Mar 16, 2014
    The fridge side is not cooling below 60 degrees. The freezer seems to working except it drains onto the floor occasionally. The fridge will cool down to about 34 degrees every couple of weeks en will steadily climb back to 60ish over a week or so. Do I have a low coolant charge?
  • Anonymous Mar 21, 2014
    model 64252402
  • Anonymous Mar 27, 2014
    whirlpool refrigerator will not cool below 52 degrees
    President:
  • 878 Answers
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
Sometimes there is a lever on the bottom left hand side of the refridgerator side that lets cool air form the freezer in --it may have gotten closed. Check to make sure it is open. Also this happened to us--we emptied fridge-turned it off for 2 days and then it was fine.
Posted on Aug 14, 2007
Refrigerator is not holding temperature. Currently at 50 degrees set a 7!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | KitchenAid KSRP25FNSS Side by Side...
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
Our side by side refrigerator/freezer is not cooling properly
first try to clean the condenser coil, it is under the bottom of the unit,blow out or vac out the coil.
check to see if fan in freezer is running or if there is ice on the evaporator coil inside freezer.
Sep 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Refrigerator will not maintain proper temperature
Check in the back of the fridge section; there is normally a control that is provided for 'balancing' the cold air between the two sections. That coolled air is distributed by a concealed fan that may not be running; you should be able to ear or feel the air movement when the unit is in a cooling cycle.
Apr 19, 2009 | Samsung RS2534 Side by Side Refrigerator
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
Open Questions:
Maytag MZD2768G Side by Side Refrigerator Logo
561 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
