Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
CL code flashing code reads Cl on toyostove ?
  • 57 Answers
The stove is doing self cleaning I believe ;) It will show cl and then 10 down to 1 and it will restart.
Posted on Nov 14, 2008
My Toyo Laser 30 has an error code EE 5 and I can't find any info on that particular code. Help?
Call manufacturer or Installer - Direct Vent Furnaces are not a DIY service. Carbon Monoxide is deadly and can easily be emitted if there is something wrong with the heater. Get professional help before anything further is done, as it needs a full inspection for your safety.
Apr 14, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 30 what is code cl
Gary
Cleaning mode, if the time is set correctly it happens at 2 am. That way no one notices it.
Feb 10, 2013 | Rinnai Toyostove Direct Vent Heater:...
What is cl code mean?
The Toyostove heaters have a cleaning cycle for the igniter. It usually does this at 2:00 am. If you don't have the clock set it will do it whenever it thinks it is 2:00 am. The cleaning cycle usually lasts about 10 minutes and it will count down the minutes only (9,8,7,6...).
Nov 17, 2010 | Rinnai Toyostove Direct Vent Heater:...
Smells like fuel no error code, burner light flashes
Turn off the gas valve! Perhaps your pilot light isn't lit, or there is some other seepage.
Regardless, if you smell gas TURN OFF THE VALVE, or if it is leaking and you cannot stop it it is VERY dangerous and you may have to call the fire department. Be careful and act FAST!!
Apr 10, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 56 error code CL02
The CL means that it is in the automatic clean cycle. The 02 means that it has 2 minutes left. It will automatically do this at 2:00 AM. If you don't have the clock set it will do it whenever it thinks it's 2:00 AM.
Nov 05, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Help plese
On a toyostove EE13 is the burner thermistor.
On the Toyo you may have to have the dealer help you, as it could be something easy like a very cold day or more complicated as a main circuit board.
Sorry but, that's the only solution.
Mar 25, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai heater flashes code 12
Bailey,
Next time you try your stove watch the flame. If the flame goes away and then the error code comes on, you have something wrong with the over temp circuit, gas or gas valve, If the code comes on and then the flame goes away you have a flame sensor problem.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Code cl
Which phone is having problems? the base? one handset? All? CL... Check Line?
Jun 17, 2007 | GE 28112 Trio Cordless Phone
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
167 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
