Sony Cyber-Shot DSC-P100 Digital Camera
Problem for Sony Cyber-Shot DSC-P100 Digital Camera
Error code E:61:00
By Rudders on Sep 03, 2006
my sony cyber-shot suddenly went wrong with the lence not reclining back into the camera when switched off unless pushed gently. when i switched the camera back on the camera desplayed an error code of E:61:00 which contantly flashes and the image is distorted and out of focus on the screen. if i switch the camera on when the lence is still out the camera beeps and tells me to switch the camera off and on with a black screen but doing this makes no difference to the camera at all.
i've tried resetting the camera which didn't help and unfortunatly i've not been able to find my instructions book to see if the code has a meaning.
if there are any solutions out there i'm very keen to find them!!
regards Suzi
Same Problem
Jul 17, 2008
-   I had the same problem with my Sony Cyber Shot DSC-T5. The error code was similar (E:61:10) so I thought I might as well give it a shot. I banged it on my hand pretty hard a few times...nothing, then tried my desk...nothing. After finding out it would be a minimum of $200 to fix the camera I started banging it harder and harder all over the camera...and lo and behold...IT WORKED! The focus is back and I saved $200 bucks! This website is a godsend - thanks everyone!!-   battles
Best Solution
posted on Jun 13, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
so funny....i just hit mine against the wall a few times and it fixed it!
Solution #2
posted on Sep 15, 2007
Very Helpful)
Esgeeque
Rank: Apprentice
Rating: 98%, 7 votes
I fixed this problem, at least temporarily, by rapping my camera against the table! At least I can postpone costly repairs for today!
Was this helpful?
Yes
No
Solution #3
posted on Mar 23, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with my Sony Cyber Shot. I brought it into a camera repair shop. They said it will have to be sent in and probably run about $200 to fix. Their response was that it is worth fixing, if you have an extended warranty.
Solution #4
posted on Sep 04, 2006
Helpful)
scrajmer
Rank: Wiz  Sony Expert
Rating: 81%, 500 votes
this error is for lense movement not working. Your camera has a fault in the movement of the lense, may be friction ar damaged gears. get the camera checked at a repairer.
Was this helpful?
Yes
No
Solution #5
posted on Dec 29, 2007
Helpful)
shake73
Rank: Apprentice
Rating: 85%, 3 votes
my lens would not close. i had the E:61:00 flashing error. i rapped my camera on its side on the table gently, and the error went away and the camera worked normally. pictures were NOT out of focus (common complaint). Thanks!
Was this helpful?
Yes
No
Solution #6
posted on Nov 29, 2007
Somewhat Helpful)
Jaustin1962
Rank: Apprentice
Rating: 80%, 3 votes
As radical as it sounds, I tried the solution of taping the camera on the table, and surprising as it sounds, IT WORKED!!! (NOT TOO HARD THough.)
Was this helpful?
Yes
No
Solution #7
posted on Sep 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Ok I cannot believe it..This completed worked and saved me $200. Thanks for the suggestion of hitting it on my hand
Solution #8
posted on Jun 30, 2008
Not Rated)
georgetabs
Rank: Apprentice
Rating: 0%, 0 votes
For DSC-W17: The lens extended (normally I thought), but would not zoom. I shut it, and it was attempting to extract-retract, but shut with the lens rather extracted. Putting constant gentle pressure helped the lens to retract while shutting, even though it was attempting to extract again for 2-3 seconds.
Harder pressure however (about 1/2 kilo strength on wooden desk) made the lens totally unoperational... :(
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-Shot DSC-P100
Questions and Unsolved Problems for Sony Cyber-Shot DSC-P100
Do you recommend Sony Cyber-Shot DSC-P100 Digital Camera?
Answer
Answer
I am having real problems with my camera not giving good shots and they use to be the best ever.... (More)
Answer
telescopic lens seems to be stuck. It attempts to telescope out but it seems stuck.
Answer
I wanted to replace the broken LCD for my sony digital camera DSC-P100. Where shall I buy it?
Answer
blank screen apon powering on and it will not perform any functions
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital... Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
