Question about Xerox Phaser 8550/DT Thermal Printer
ERROR MESSAGE 8550/DT
ERROR MESSAGE 09,035,43;101292
  • 728 Answers
Can you please tell me what your device is and the brand and model number. But I am guessing it is a printer.
Posted on Oct 28, 2008
  • Xerox Master
  • 19,396 Answers
I can check if I find the service manual.
  • Ginko
    Ginko Oct 28, 2008
    09,035,43 means low ink, you need to replace/refil the ink or perform an ink test.
  • Ginko
    Ginko Oct 28, 2008
    The message (error code 09,03..4..) means ink stick count fault , you get this error code when the
    printer melts 2.5 ink sticks without finding the color's ink out flag, that is used to count the ink stick usage .
    In details, the error message concerns the Cyan ink stick, check in the ink loader if the stick is stuck or broken.
    Ensure that ink sticks used are original Xerox ink sticks.
    Check that ink sticks are correctly loaded, they are not broken, and that they are free to advance in the
    ink loader. C
    After checking everything, select the diagnostic menu, scroll down to find the Functional menu item Clear ICS Fault, and clear the fault.
3 Suggested Answers
  • 2072 Answers
SOURCE: Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Posted on Apr 22, 2008
  • 81 Answers
SOURCE: xerox error code 09 035
What model printer?
Posted on Jun 10, 2008
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Liftmaster 8550 get error code 14. Why do I get this message and how to resolve this?
error code 14: is telling you that your sensors (6" off the floor) both sides of garage door are misaligned. check sensors, make sure the lights are on, move them around and tighten them down
May 27, 2014 | liftmaster Chamberlain Garage Door Opener...
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Xerox 8550DP error message (16.4)
Even if your printer's front control panel display has not gone bad yet, it could only be a matter of time.
If your printer has never had its control panel display replaced, you can get a free replacement from Xerox, even if the printer is out of warranty. Just call 877-571-7765 with the serial number of your printer.
I think this is due to a known defect from the factory for many of these panels having a bad soder weld which eventually causes issues with the panel, even if not apparent at first. That was the case I had. Just one day out of the blue my panel went blank, some days its lit with no display others the display is upside down or reading gibberish other times it seems to work fine. I tried looking for a bad soder myself but couldn't find it then later found out there was a soder issue via another post on this site and they will replace this panel free of charge.
Dec 10, 2009 | Xerox Phaser 8550/DT Thermal Printer
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
Here is your problem.
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Phaser 8550 printer fault 37,008.44:25860
This is a pre heater error.
I would make sure the printer is connected directly into the wall and not into a power strip or UPC as these devices may create momentary AC voltage sags that could cause this error. If power levels going into the printer are good, you will need to contact Xerox for support
Jan 13, 2009 | Xerox Phaser 8550DP Printer
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Apr 22, 2008 | Xerox Phaser 8550DX Laser Printer
Phaser 8550 cyan doesn't print
If you go to the Xerox.com site and click support and drivers. enter phaser 8550 and there is a printhead update you need to get, You have to fill out a form.
That may be your problem since there is no fault code.
Apr 13, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser  8550/DT Thermal Printer Logo
220 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
