Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu5314 won't heat the water.
Everything else works fine but it won't heat the water. Do I need to replace the heater? thanks, gregg
  • 2 more comments
  • stetzer Nov 09, 2008
    Well thanks is that a fairly easy replacement job for someone mechanically inclined?
    Can I get step by step instructions since I can't find a repair manual.?
    Thanks and the Control Module Part?
    a little
    Genius:
  • 1,550 Answers
You can get manual from this link
Bosch
Posted on Nov 09, 2008
    President:
  • 2,712 Answers
It could be a faulty heating element or control panel. Also check the wiring for continuity, etc. However, if you do not have experience in these type of repairs, I would suggest you leave it to the repairman to fix.
  • 13,433 Answers
Yes the heater is most likely the problem
My Bosch aqua star water heater lights but won't heat my water
Unplug micro switch located on bottom of water heater if it has one
Dec 30, 2012 | Bosch AquaStar Indoor Natural Gas Tankless...
Won't heat water
Glad it worked out so easily.
Be sure to perform the regular maintenance as shown in manual to prevent common error codes.
Sep 25, 2012 | Bosch ProTankless GWH C 800 ES LP Tankless...
Our tankless water heat will not heat the water-it won't ignite
Question posted under Boasch tankless. Model number not known.
Before calling service technician, open following link for Bosch troubleshooting resources, including phone and contact for Bosch, error codes, and possible manual, plus hours of reading and research:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
As you know from reading manual, tankless water heaters require yearly maintenance by trained service technician, or by homeowner. This action would check gas and pressure, venting draft, condensation drain, burner and combustion parts, igniter and-or pilot light, electrical connections, air intake and general condition of plumbing.
Problem you describe does not include error code.
Open following link for possible help with general plumbing problem:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Add a comment with model number that appears on side of unit, and I can directly locate possible service bulletins and further troubleshoot resources available at Bosch for possible do-it-yourself diagnosis and repair.
Sep 02, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch dishwasher not heating the water at all but everything else is working fine
This needs the heating element checking & replacing if defective. There are also possibly 2 thermal cut-out switches that need checking too. Replace if not working.
Aug 20, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Seven months ago, a bosch alled at my house
you will always have this problem in city type of appltcations.there is too much of a flow differation.
Jul 13, 2009 | Bosch 2700ES Natural Gas AquaStar ...
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H-LP Overheating Problem
did you check to see if your temp regulater is working properly? also you have a thermocoupler that senses the heat of the water and works in conjunction with the regulator. have either one or both replaced and the problem will be solved. please rate this thanks
Aug 27, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
BOSCH WFF 200L
heater element may have gone, when you manually advance the settings you are skipping the heat cycle.
Jun 02, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch 24 in. SHU53 Built-in Dishwasher Logo
78 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
