Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
5300 kodak printer installation
Lost rachel last night as she asked me to restart the computer and coudn't get back to her conversation. i uninstalled and reinstalled and it still say print job failed seems to be no communicatin between printer and computr.
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the direct "Ask Me".
I was under the impression that she did respond to your post here as she has responded to my headsup.
Might I suggest that you:
Signin back to FixYa;
view/go to the Chat Session Transcript;
somewhere down the bottom would be "Post a Comment..." right below the "Print Session"
thereafter, the system would post both of your responses and seemingly continue the Chat though with some time delay.
Good luck and kind regards. Thank you for using FixYa again.
Posted on Oct 28, 2008
I gota dell windows 7 computer when i try to scan with my aio 5300 easy share a window pups up that reads .. YOU NEED A WIA DRIVER TO RUN THIS DIVICE
Did you install the Kodak software before connecting the printer to the computer? http://support.en.kodak.com/app/answers/detail/a_id/36460/selected/true has the software for Windows.
This error usually means that you installed the generic driver from the OS which only runs printer. Uninstall the current driver, disconnect the data cable (USB) and then restart your computer. Install the software from the Kodak site above. Then connect the data cable when prompted to do so. Try scanning after completing the installation procedure.
If you did install the Kodak software, it may have gotten corrupted. Please follow the above directions and let me know if you have any problems.
I hope this helps.
Mar 26, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have the Kodak 5300 All in one easy share printer. Less than a yr old. Also a Del computer with Vista Operating system, Less than a yr old. About a week ago decided to take the time to learn the kodak...
try using the system restore option on Dell computer.........as you have vista,,,click on the start button and type system restore in start search box and follow the on screen instructions and select yesterday's date and proceed.......should help:)
Apr 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5300 won't install on my Mac computer
go to your control panel and uninstall any printers including kodak then restart you computer, then try installing your kodak, Rob
Feb 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lost
hi. if you go to the site below you can download what you need, also manuals if needed...
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
Oct 17, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak aio printer 5300/software problem
Greetings Jackie,
Sounds like you have a failed .netframework installation. This is a Microsoft feature, but is delivered during installation of Kodak software as well. To fix this, do the following.
1. Open the Control Panel.
2. Double-click Add / Remove Programs (Windows XP only).
3. Select Microsoft .NET Framework 2.0.
    IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove.
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
    1. Follow steps 1 - 4 above.
    2. Select Uninstall, and click Next.
      IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
    3. Restart the computer.
    4. Perform a clean re-installation of the KODAK AiO Home Center software:
      a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
      NOTE: Do not disconnect your mouse or keyboard.
      b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
        i. In the Control Panel, select Add or Remove Programs (Windows XP).
        ii. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
          • Kodak EasyShare software
          • Kodak all-in-one printer software
          • Kodak EasyShare 5000 series all-in-one software
        iii. Click Change or Remove (Windows XP).
        iv. When the Install Wizard appears, click Next.
        v. Depending on the issue(s) you are experiencing, do the following:
          • If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
          • If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
        vi In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
        vii. In the Ready to remove the program window, click Next.
        viii. In the Uninstall Complete window, click Continue.
        ix. Restart the computer.
      c. Delete the files and folders that can interfere with the installation:
        • Printer folder in C:\Program Files\Kodak
        • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
        • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
        • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
      d. Run Disk Cleanup.
        i. Open My Computer.
        ii. Right-click Local Disk (C:) and select Properties.
        iii. Click the Disk Cleanup button.
        iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
        v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
        vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
      e. Shut down all background applications.
        i. Select Start > Run.
        ii. Type msconfig in the Open field, and click OK.
        iii. Select the Startup tab.
          IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
        iv. Click Disable All , then click OK .
        v. When prompted, restart the computer.
      f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
      g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
      h. Before restarting the computer again, turn on the background applications.
        ii. Type msconfig in the Open field and click OK.
        iv. Under Startup Items:
          - If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
          - If all background items were originally selected, click Enable All, and click OK.
      i. Restart the computer.
      Once restarted, you should be OK.If not call our 800 421 6699 and they will help further.
      Best Regards,
      Ron Baird - the friendly Kodak guy
Sep 18, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Aoi 5300 printer
Have changed both ink cartridges and print quality is still VERYpoor. Have re-calibrated printer, restarted computer, still no change...please help.
Thanks
Aug 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
2 Problems: 1) Unable to get printer to print from desktop; 2) Kodak SW won't install on laptop
Download and install the new software and printer firmware from kodak.com (link below - firmware and software is the same for all the 5000 units). Do not use the CD, and Uninstall all previous versions before installing the new software you download from the site.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=mac_os_x_10_5_x&downloadLanguage=en
I hope this helps. If you still have problems respond to this message with what happens and I will try and get you more help
SDtester.
Mar 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
c. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Problems
you don't mention what kind of printer, but try this, unplug printer and have it connect to pc, plug back in and turn power on.
see if computer see's it.
Dec 03, 2007 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
