My intertherm is not working at all
The central air was working turned it off when it cooled down went to turn the heat on and we have nothing at all only two years old
    New Friend:
  • 30 Answers
Check the breakers at the bottom of the unit. the ones for the heat strips may be tripped.
Posted on Oct 30, 2008
Intertherm unit : heat is on and Iam energized at the motor but It does not turn on !! Blower motor works on cooling!! ???
try to switch the speed of the blower to a diffrent speed to se if that works(usually its the red wire for heat) . make sure to turn power off before disconnecting.
Jan 14, 2011 | Intertherm Heating & Cooling
I have a Intertherm heating and air conditioner it is a Manufactured Home. The furnace model number is E2EB-017HA. When you flip the switch to heat and move the control arm up nothing happens. You can go...
When you turn the on/off switch to on you are turning on the "fan switch" and the blower motor is only coming on. When you turn the switch to cool and move the tempature control lever down you are turning on the air conditioner...So it sounds like your heater is not working. Is the heater electronic ignition or does it have a pilot? If it has a pilot the heater may not be working because the pilot is out and will need to be lit. If it is electronic ignition you will need to inspect the unit to determine what component is faulty. Could be the igniter,gas control valve,ect. Verify that gas is not shut off to unit at line valve and gas control valve on unit.
Oct 07, 2009 | Intertherm Heating & Cooling
Central heating HVAC blows cold air -
is there a light or source of heat near t stat or low battery in tstat
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm heating
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Oct 29, 2008 | Intertherm P3RA-048K Air Conditioner
Adding a Condensing unit to an Intertherm electric furnace
you have the motor connected on more than one speed in heat mode. make sure inly one mode is connected
Oct 19, 2008 | Intertherm P3RA-048K Air Conditioner
Elec. intertherm FURNACE
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Jan 05, 2008 | Heating & Cooling
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
