Question about kawasaki Drills
21.6 VOLT RECHARGEABLE POWER PACK WON'T HOLD A CHARGE
RECHARGEABLE BATTERY PACK [21.6 VOLT] DO NOT HOLD CHARGE. S/N'S ARE 6080042490 & 6080042493.
    Top Expert:
  • kawasaki Master
  • 77,499 Answers
There is nothing to do but replace it, they do wear out.
Posted on Nov 07, 2008
Nwz-w262 battery will not hold charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Audio Players & Recorders
Will not hold charge
Nov 02, 2012 | Kodak EasyShare DX6440 Digital Camera
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
My eclipse cld 4gb mp3player wont hold a charge
Oct 17, 2012 | Mach Speed Trio Eclipse 4GB CLD MP3 Purple...
Alienware m14x battery won't charge
Remove main battery, get a stiff toothbrush and clean battery terminal in laptop and prongs on batteries. Install battery and charge, if no change! rechargeable battery needs to be replaced.
Mar 22, 2012 | Dell Alienware M14x Notebook
My Mintek portable DVD player's battery will not charge. I have rarely used the battery so I can't believe the battery is dead. The AC cord works to power it when plugged in. Why won't it...
After a while even rechargeable batteries loose the ability to hold a charge. This process accelerates when the battery is allowed to lie completely discharged for long periods of time. NiCad batteries especially have this issue. If you left the battery sitting for long periods without occasionally charging it, it losses the ability to hold a charge. It appears you are going to have to either do without the battery or replace the pack. I would take out the old one, it will eventually start to corrode and leak and if its still in your machine it will cause damage. If you get a new battery pack make sure you charge it fully and then depleat it completely before recharging it. hope this helps.
Jul 26, 2011 | Mintek MDP-1880 8.5 in. Portable DVD...
A320s battery has full charge , tested with volt meter. computer shows 6% battery
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 08, 2011 | Getac A320S PC Notebook
Milwaukee tool 18 volt nimh battery won!t charge
If the battery pack is more than 2 years old its time for a replacement. The typical charge/discharge life cycle of a rechargeable cell is 500 - 700 times and the shelf life is about 3-4 years from the date of manufacture. If the charging indicator lights up when you dock the battery on to the base and still does not work after 5 hours - its due for a replacement.
Apr 08, 2011 | Dewalt Accessories Batteries 18 Volt
Ultimate Wall-E robot won't hold a charge
I found this battery and it works with my Ultimate Wall-e, even charged with the charger that came with Wall-e:
http://www.lynxmotion.com/p-67-72-volt-ni-mh-1600mah-battery-pack.aspx
Feb 10, 2010 | Thinkway Toys
New Haier 7.2V rechargeable NI-MH battery pack for a new Haier Portable DVD player was stored in a drawer for 2 years until recently. Attemped to recharge battery pack via electrical outlet. Obtained...
the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
Oct 02, 2008 | Televison & Video
Drills Logo
522 people viewed this question
Top kawasaki Drills Experts
jasbo
jasbo
Jim London
Jim London
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
