Question about HP Photosmart R817 Digital Camera
Zoom is broken
my hp r817 camera falls down and the zoom is broken, but i can turn it on and see the pictures saved on it.
i want to fix it
  • hanan_nak Oct 28, 2008
    please i need to fix it
Just call bob the builder; because 'yes they can"
Posted on Apr 29, 2009
New computer with windows 7 will not allow run install disk for R817 digital camera
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use Windows Photo Gallery or any other photo cataloging program.
Sep 05, 2011 | HP Photosmart R817 Digital Camera
My lenses wont retract and my camera has a error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2010 | HP Photosmart R817 Digital Camera
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
May 31, 2009 | HP Photosmart R817 Digital Camera
Camera self- diagnostic doesn't work
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Dec 23, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817
Something is wrong with the battery or the charging system. I just charged it over night and it works now. The battery still dosn't last very long .
Oct 07, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817 5.1 Megapixel
Lens does not come ut when we turn camera on?
Jun 30, 2008 | HP Photosmart R817 Digital Camera
All zoom pictures blurry
I am sure your lens is clean but from what you describing you have a definte problem with the lens assy which includes the autofocus sensors. Sometimes is can be a faulty focus motor , dirt between sensor and outer lens. Camera needs to be stripped and checked up.
Mar 27, 2008 | HP Photosmart R817 Digital Camera
"Charging Flash"
i just posted the same problem a few minutes ago and now i have the solution!! got to this link
download the driver if needed (the firmware installation will tell you if you need it) and then download the firmware. immediately after i downloaded the firmware, the "charging flash" went away! hope it works for you too~
Aug 22, 2007 | HP Photosmart R817 Digital Camera
HP Photosmart R817 Digital Camera Logo
151 people viewed this question
Top HP Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
