Question about Compaq Presario Notebook
Wont boot up
Tells you to press f8,f9,orf1 but still wont start
    Problem Solver:
  • 10 Answers
Maybe an HardDisk issue, find the model of your HardDisk then download the diagnostic tools from the manufacturer internet site to test it.
Posted on Oct 29, 2008
Not shown booting options
f8 or f9 shows the booting option
Aug 08, 2013 | Toshiba Satellite A15-S127 Notebook
My laptop cant boot normal to w7
app laptop up key F8 AND F9 click to automatic boot
Jun 20, 2013 | Computers & Internet
Unable to restore
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Nov 26, 2011 | ASUS Eee PC 1001P Netbook
Ibm p4 seystem window xp2 installation method please tell me
step-1:- cdrom ko first boot device bannaa ya pc ko start karke f9,f10,f11,f12 with press karo uske bad main cd rom ko selesct karo,
(press ant key boot fromcd............) likha aane par koi bhi key press karni
step2 :- iske bad main enter press karna
press f8
press enter
then select ntfs quick format
press f
then 33 minute remaing then product key dalni hain
tbhxm h6w74 4d8gm b6xx4 m29t8
next
next
next
Jun 09, 2011 | Computers & Internet
Wont boot tells me to choose f10 or f 9 nthen wont do anything no matter what you choose.
i press f9 and f10 it say when i turn my laptop on no boot device insert boot device and press any key i dont have a boot device
Mar 07, 2011 | HP Mini 1000 Netbook
Hi when i satrt up my hp compaq mini 110 it wont load past the bios. it comes up with the options for F9: change boot device order, F10:BIOS setup options, F12: Network boot. if i leave it to laod past...
Check to see if any media is in you CD DRIVE, or any other drive because if BIOS is booting from the CD or other media first, it never gets to your hard drive thus never boots windows. If clear, Press F9 and enter into your BIOS setup. You will have to make sure your boot sequence/order is in order to boot first from the hard drive. If all is in order try F8 hitting it repeatedly until safe mode options appear. If this doesn't work post a reply and we'll go from there.
Jan 11, 2011 | Computers & Internet
Good Afternoon, I have the Acer Aspire 10''
From the symptoms, the computer Operating system seems to be corrupted.Try to follow the steps
Try booting to BIOS by punching DELETE / F2 key on startup.Then press F9 key, load the defaults.After that press the F10 key to save them and then start tapping the F8 key to get the repair my computer options.Select safemode .If the computer is booting to safemode, you can try doing a system restore.If the unit is not booting to safemode, then the Operating system has to be reloaded.
Oct 24, 2010 | Acer Aspire One PC Notebook
Hi i have a avdent laptop and i says i dont have enough bootable volume it wont let me load my laptop up i got a boot cd but i dont know how to use it, also has this laptop got a reset button thanks.
is your hard drive full it sounds like it ok reboot your pc hold the delete button and you will be in the bios find your boot sequence and make your cd rom the first then hard drive second and 3rd and 4th what ever you want then put in you cd save and quit your bios and it will ask you if you want to boot off the cd you say yes if this does not work hold the f8,f9,f10 till you see a screen that says you can boot in safe mod do that and if your hard drive is full try deleteing some larg files or do a disk clean up right click your hard drive click go to the bottom of the list and look for tools and do a disk clean up i hope this helps
Mar 30, 2010 | Computers & Internet
Dell optiplex 760 won't go into safe mode
It sounds as though your PF keys are disabled by the BIOS settings. Try this:
Upon cold start or reboot get to the BIOS setup. You may have to press F2 or delete, or whatever key the first POST messages instruct you to use. Different BIOS manufacturers use different keys, and you have to be quick to interrupt the boot process using the correct key. If you fail to determine what key it is, reboot once again, until you see/read what key does the job.
Next, once you're into the setup screens, look for a section where you can set/deny access to the F8, F9, F10 etc keys during the boot process.
Make sure you ENABLE them, following the instructions on what keys to use to set/reset these choices. Make sure you SAVE AND EXIT.
On the next reboot, upon the disappearance of all POST messages, make sure you press the F8 key repeatedly until you see your OS boot options menu, among which you'll find Safe Mode.
Aug 24, 2009 | Computers & Internet
Hp 9695c wont boot only ht HP banner shows but wont go to the initialization
Press and hold down Shift key, when you hear the beep, until system boots.
If you dont time it right you will get a keyboard error, dont worry, just press F1 key and immediately hold your Shift key again.
Your system should boot into basic mode, then you need to check your system for virus or last software that may have been installed.
Nov 25, 2007 | HP Pavilion dv9000z Notebook
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
