Question about HP Pavilion dv4000 Notebook
For all those with a Flexed Chassis Freezing issue!
I've had the same issue. I've stripped it down twice looking for a solution only to have the same problem. My solution was to place two pens under the laptop (one on each side)near the area between the keyboard and touch pad. Then put one hand near the screen hinges and one hand near the front speakers and bent the laptop chassis back to OEM shape. I worked from one side to the other and haven't had any freezing problems since. You can get another motherboard but with a flexed chassis you'll always have the same issue. Hope this helps..
  • bob1ell Nov 04, 2008
    Hello I have this problem with my DV4000 power up THERE IS three(3) beeps display is blank but all lights are on (power,sound lights etc,etc)
    I though it might be the hard drive or sys board or even keyboard.
    can anyone shed any light on this problem?
  • 520 Answers
Download a program called paragon and unzip and follow instructions to create a boot disk and install program on it.once done with the created disk in drive turn on pc.the disk will boot up and a program will start to check or/and edit youre hd.
if it detects bad sectors(which is what seems to be your prob) repair them;bet way format entire hd.
this is probably the best software type for repairing difficult to fix hard drives .
Posted on Nov 10, 2008
My Acer happy keeps on freezing and not responding. I've formatted it twice but still having the same problem..
Remove one stick of ram and test, if no change! remove the second piece and put back the first, if this works! the memory stick in your hand is defective and will need to be replaced.
Apr 01, 2012 | Acer Computers & Internet
Hi, bugs are flying into our home when we put our air conditioner on fan mode. What can we do to avoid this? Thank you.
Your owners manual is here:
(slow download for a small file)
I checked to see if there was an external venting function for your unit and there was not so we can eliminate drafted external air as the source. What you will need to do is check the outer chassis to see if the foam is torn off that seals the unit off from external air. You will see a foam strip in the very top of the chassis if you slide the internal unit out. Get some single sided weather stripping and seal off the inner chassis by applying it to the the outer chassis. The from should make contact with the evaporator shroud area only ALL the way around the unit. It will be trickey to get it on properly and then slide the unit back into place but this is what you need to do in the inside of the outer chassis. Now.... on the outside of the outer chassis it must also be sealed. This is just a stretched foam strip all the way areund the outside of the outer chassis. DO NOT use adhesives. It is a stretch and stuff in place fit only. A putty knife works great for installing the outer foam as you stretch it out. If you have any gaps make sure that the gaps are not in the coreners and use another piece of foam to fill any side gaps if the foam pulls apart.
This should resolve the bugs with fan only issue.
Thanks for choosing FixYa,
Jul 09, 2011 | Frigidaire FAS257S2A WallWindow Air...
My right rear turnsignal has stopped working...the front still works, but flashes faster than normal, indicating a bad bulb...I've replaced both right side rear bulbs with no change...I've checked...
It's almost certainly a wiring issue. Very likely, the ground (-) connection for the tail light has severed or is not making good contact with the chassis. Look for a black wire running from the tail light housing to a screw or bolt on the chassis. You will find that the wire has either become severed, is loose, or is simply not making a good connection. A little WD-40 (penetrating oil) on the screw or bolt where the wire connects will assure that corrosion isn't the issue.
Hope that's helpful!!
Jul 01, 2011 | Chevrolet Silverado 1500 Cars & Trucks
Turn signals not working, hazzerd works, fuses ok, what to look for
Most motorcycles use a "flasher" to operate the signal lights.Older ones used a mechanical type that heared up a bi-metalic strip that flexed, then cooled down and make contact again. usually it made a clicking sound. they are very similar to the auto flasher that you can buy in any auto store. newer ones use an electronic type with transistors that time the operation. The older ones used a lot of current and if the battery was low, then they tended not to fully operate. the newer ones use very little current and operate most of the time if the battery is reasonably charged. The flasher looks like a small can with two or three blade plug ins, that plugs into a position on the wiring harness.
Feb 09, 2011 | Honda GL 1200 Interstate Gold Wing...
Why do you want to get to the lens? Do you think it`s dirty, if so, try buying a laser lens cleaner, It will be a lot simpler and safer than stripping the set down.
In answer to your original question, Yes, You do have to strip the set and then you`ve got to strip the DVD player because it is buried inside a metal can. Then you`ve got to clean the lens, put it all back together, Praying that the fault has been cured. Please buy a cleaner first, I used to repair these kinds of sets and they are a nightmare, and I`ve been down this road before and it really is an awkward job especially when you put it all back together and then find that the CD door isn`t properly located or a lead isn`t connecting properly or a lead broke as you removed it. I`ve been there, I`ve got the T shirt. Ian
Jul 28, 2009 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Power supply board needed from a Akai LCT3285TA 32" LCD TV
Go to this is where I found the power supply board for this TV.
Jun 30, 2009 | Akai LCT3285TA 32 in. LCD Television
Freezing 360, vibrating controller, colored lines on screen.
3 red lights is the red ring of death, 4 means your AV cable is disconnected. If it freezes up though, you have a bad DVD player in it. I would send it back.
Jan 09, 2009 | Microsoft Xbox 360 Console
Hi, sounds like a loose component inside your computer. Probably not worth looking at yourself if it's in warranty, get it sent back to Toshiba.
Mar 27, 2008 | Computers & Internet
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Phone keeps freezing
u need to do hard  reset of ur fone and pls take back up before that...or else there is problem with charging slots pins and turn on/off button,,,,,,,,
Sep 09, 2007 | Nokia N95 Cellular Phone
HP Pavilion dv4000 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
