Every time I put a dvd in the dvd/video combo I get the message 'cannot record on this disc' E24 I have bought the recommended JVC 4x DVD's Thanks
  • 31 Answers
Try and use a laser cleaning disc or manually clean laser after taking cover off then use a wet q tip then use a dry q tip to absorb excess moisture. or pherhaps do a search for firmware update for ur model.
C
Posted on Oct 29, 2008
What other blank dvd's will record on sylvania srec427 , besides maxell 2x , 4x ( these are the ONLY ONES that would record on this tv/dvd/vhs/cd combo . what other brands will work ? i've tried ab
Your combo device will accept all bands of recordable DVD but only the minus R or minus RW not the plus R nor the plus RW I've had great success using Staples brand of DVD-R/RW and is usually very competitively priced if its in stock but I've found that Maxcell & JVC brand are often on sale at some of the major big box MEGA stores nationwide that is also an awesome and reliable disc that I use and can recommend
Jan 08, 2015 | Sony Televison & Video
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't record and never has. get disk error e24
Anyone know where I could get a free download for a Emerson Dvd/vcr combo firmware upgrade??? (Ewr20v4) I need it right away . Emerson will charge to mail me one.
Nov 14, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Can't record to DVD
make sure it is a dvd-4 8x or lower if you have the service pac....4x or lower if not. 2x dvd-rw. hope it helps
Jan 27, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
DVD will not finalize
I have found that any disc faster than 4X will not finalize. 8x disc will record but not finalize. 16X disc will not even record. I haven't been able to find any D VD+R 4X. 4X disc work fine and will finalize if you can find any.
Mar 16, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
JVC DRM10 DVD Recorder Problem
This unit is showing and error message "Disc Not Recordable" with a maxell DVD-R 1-16 Speed Single Sided Recordable DVD.
Nov 09, 2007 | JVC DRM10 DVD Recorder
Jvc dvd/video recorder
Time for some laser work. You have a disc read error...accordianman
Oct 02, 2007 | GoVideo DVD-VCR Combo
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
