Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Green line problem
I have a green line on the left side of my tv from top to bottom the picture is not centered its off to the right. this only happens on hd channels. help please
  • 3 Answers
I had the same problem when we hooked up an hd satellite box. It's a simple solution using the Philips remote that came with your tv. The dial in the center of the remote with up down left right control will move the picture left or right up or down by holding the direction you want to go. Make sure to stand in front of tv.
Posted on Mar 18, 2010
  • 90 Answers
Problem with digital board -- going out-- just like a picture tube in an old television
Posted on Feb 24, 2009
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Tv set picture is gone
It depends, the center line you speak of, does it go from side to side? Or top to bottom? Side to side you have problems in the vertical circuit. Top to bottom you have a problem in the horizontal circuit. Not picture tube problem. If it is an analog tv and depending on how old it is. What an estimate and the actual repair would be you are better off buying a new one.
Jan 27, 2009 | Televison & Video
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Green line on TV with DVD playing
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Mar 07, 2008 | Philips HTS-6500/37 System
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
284 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
