Question about RCA D52W19 52" Rear Projection Television
WILL NOT POWER UP
When you plug the power cord into the wall,the green light
on the power button flashes nine times;pauses for two sec;then flashes five times. It will do this for as long as you
leave it plugged into the wall,but it will not power up!
When you unplug it from the wall plug,the green power light will still flash in the same sequence for about ninety seconds before going out.
    Genius:
  • 1,030 Answers
Your set has gone into shutdown mode. THis set has a microprocessor that has detected a condition in one of 25 different cuircits that has presented a saffety issuse. so it has prevented turn on. This condition tells you that one your main fuse is still there and the processor is getting power. The most common causes of this shutdown are bad flyback transformer and horizontal output transistor has shorted, However it could be any of 25 different problems. Techniicans have a computer interface that read error codes much like that of a automobiles.
Posted on Nov 07, 2008
How to turn on hp 3600
Unplug the power cord from any surge protector, extension cable, or power strip, press the power button on the printer several times. Plug the power cord directly into a wall outlet.
Feb 21, 2015 | HP DeskJet 3650 InkJet Printer
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
Apr 16, 2014 | Belkin Computers & Internet
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
Laptop will not start
power drain the laptop, by removing the all the connections and battery.
Then press and hold the power button and check for the issue
if perists, reinstall the operating system and check for the issue
Apr 05, 2010 | Dell Vostro 1500 Notebook
My canon ip1880 printer orange light flashing 7 times even after I have installed both my cartridges correctly.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Oct 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Power button blinks, tv won't turn on
replace the flyback, that should straighten it out. You need flyback 259296 you can get one at the following link with free step by step instruction on how to replace it, from beginning to end.
http://servicemanuals.vstore.ca/
Sep 05, 2008 | RCA HD52W59 HDTV Projection Television
I have a Canon BJC-80 and when I turn it on it goes through the on process, but then the error lighs up and beeps then the green power light just flashes green. What do I do?
well..disconnect from computer first
turn off power
unplug from wall(it's installed in wall, right?)
press power on button down, after 30 sec of off time
plug it back in with power button held for 10 sec
see if that helps a bit
Aug 19, 2008 | Office Equipment & Supplies
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
