The camera turns off as soon as i plug the usb into the pc are if i plug it in then try to turn it on it just beeps then will not come on at all.But both the pc and camera work JUST FINE by them self, and all software is installed right so i dont know what the issue is and REALLY NEED HELP!!!!!!! SO I CAN PUT MY PICS ON MY PC....
Try NOT plugging your camera into your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
SOURCE: my Kodak easyshare c190 won't turn on, it just
Are you using alkaline batteries? I had the same problem -- my camera cut out after just a few pictures and when I tested the batteries they were practically full. But alkaline batteries, even 'super-heavy-duty' ones, aren't powerful enough for this job. You need better, preferable rechargeable batteries.
SOURCE: CAMERA ISSUES--KODAK easyshare C613
Easier Way:
Turn on the camera without the cord plugged in, and push the Menu button in back, scroll down to the SET ALBUM (STILL) which is probably in the OFF mode. When you hit OK it will probably tell you to connect to the computer. Then you plug in your cord.
You may have to put your Easy Share disk in at that time and load or reload the software but it should then allow you to download all your photos into into a Kodak folder. Then you can burn them to a DVD or select as many as you want and move to a regular folder on your computer.
SOURCE: Kodak EasyShare C613 turns off when connected to PC
The camera is supposed to go blank when connected to computer.
I hit the "share" button and can then download photos, even though screen is still blank.
SOURCE: I am looking for a self timer on my kodak easyshare m1063 camera
Yes there is.
In any Still mode, press the arrow down button repeatedly.
You can go to www.kodak.com/go/manuals
Download the extended user's guide of the manual.
Look under
Using the self-timer
SOURCE: connecting my kodak easyshare
Try w. a different USB cable.
Try w. a cardreader.
NB: When transferring the light in the lamp should be on but the LCD is suppose to be black and is not displaying anything
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
