Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Jennair 8895AAS i just bought a new dual fuel/oven stove, installed the lp conversion kit, but burners are not even clicking nor self light. works fine when i use match to light. please help.
  • DaCosta Ian Sep 06, 2006
    catriver, thank you very much for your fast response..i have a three wire configuration. i bought the wire from home depot and it is all grey witha green wire in the middle which ofcourse i attached to the middle bolt and the other two on the outer bolts.
    i appreciate your assistance.
    President:
  • 878 Answers
Flustered, first thing I would check is the power. If you are using a 4 wire 240V, part of the copper ground strap just below the terminal block should be removed. You would have black on the left, white in the middle, red to the right and ground to the ground screw just below. 120V from left to center, 120V from right to center and 240V across the outside terminals. If you have it wired right check for voltage at the spark module, should have 120V at terminals L&N. If you have that voltage there and still no spark with your burner caps on (this is the ground for the spark) you more than likley have a bad spark module. Call for factory service since this is new. Catriver..post back.
Posted on Sep 04, 2006
Does it have 2 plugs 110 and a 220
This is the oven spec, so it has to be 220 volts to support that wattage. The oven and broiler are electric and the hob is gas. Best of both worlds. (I am a chef)
Oven-Bake Element 2500 Watts
  • Oven-Broil Element 6 Pass 3400 Watts
    and then I found this :>)
    Power Power Supply Connection Location: Left Bottom Rear Gas Supply Connection Location: Right Bottom Rear LP Gas Conversion Kit: Included Voltage Rating: 240V / 208V / 60 Hz Connected Load kW Rating at 240/208 Volts: 3.7 / 2.8 Amps at 240 / 208 Volts: 15.4 /13.5 Minimum Circuit Required: 30 Amps
  • Frigidaire FGDS3065PF 30 Slide In Dual Fuel Range with 4 Gas Burners...
    Jan 31, 2016 | Frigidaire Gallery 30" Self-cleaning...
    Control knob doesnt adjust flame height?
    Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
    Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
    Flame too high on gallery gas stove
    Hello Carlos - Does you range have an LP conversion kit installed? If so, I would recommend verifying that unit is set to appropriate fuel and fuel conversion kit is finished. Also trying adjusting the pressure regulator and/or air shutter.
    Sep 16, 2012 | Frigidaire FGB24S5A Gas Single Oven
    I will soon need to convert a 1993(?) CALORIC Kitchen Range back to Natural Gas from LP. When I installed it, NG was not available, so the propane company guys converted it to LP. I was not here to learn...
    First check the regulator valve on the back of the stove. Chances are it is a dual purpose valve and once you are ready to do the converstion.. you simply will move the lever or change the setting from LP to NAT.(obvisouly before proceeding you need to have the fuel supply turned off to the appliance)
    Next check under the range lid or on the back of the stove for the spare NATural gas orifices.. when they changed it out for you there were two scenarios.. the range (most do) came with a set of LP orifices..and they simply changed these out on each burner supply including brolier/oven. (orifices are interchangeable nozzles that are threaded into the supply gas burner)
    If they had to swap out the regulator chances are they would have given you the one that came with your stove.. However I am fairly sure the regulator is a dual purpose and you simply need to change the setting from LP to NAT.
    DO NOT DO THIS WITHOUT CHANGING OUT THE ORIFICES FIRST.
    If you cannot locate the spare orifices/spud/nozzles (they are called all of these) on the stove itself you will need to buy a set. A good appliance parts store will be able to help you with these.. again.. you will need one for each burner/burner supply.
    If you can locate the range manual it will have instructions on how to do this.
    Chances are your Natural Gas company will be able to help you with this.. especially if the regulator is dual purpose.. even if you can't find the orifices they are inexpensive.. fairly standard and easy to acquire. Usually just called a "conversion kit".. it will just consist of four or five small threaded 5/16 brass nozzles/orifices.
    The installation is pretty straightforward. Again..a good appliance parts store may recommend a service company...and if your not familiar with diy repairs on a gas appliance.. a 50 to 100 dollar service call is well worth the money.
    Best of luck to you!
    Apr 11, 2011 | Ovens
    Need instructions and part # for lp conversion kit on MGR5765QDS
    Your conversion jets are usually located beneath the hinge area or the back panel on that stove and are mounted on a plate which holds all of the LP jets in a row. there is no need to buy a conversion kit, since it is already supplied. The jets mount on the burner control itself as it enters the gas flow tube, and the oven jet mounts just before the large burner under the plate in your oven area. Just remove that large oven floor plate and you will see it.
    Mar 23, 2010 | Maytag MGR5765QDS Stainless Steel Gas...
    How do I utilize the self cleaning part? Do I just press ''clean
    1. After self cleaning the range the door won't open
    2. Amana gas range conversion from NG to propane
    3. A tip on cleaning the surface grates
    4. Checking an common oven temp sensor
    5. Checking an common oven temp sensor: What does an oven temp sensor look like?
    6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
    7. GE gas range conversion from NG to propane
    8. How to change the oven temp on some common electronic controlled ovens
    9. How to re-light a surface or oven pilot light
    10. How to change a common oven glow igniter coil
    11. How a common gas valve works - click here.
    12. How Ranges, Ovens, and Stoves Work
    13. Help for storing an appliance
    14. Important Disclaimer
    15. Installing a gas flex line connector
    16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
    17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
    18. My gas range flames die when I turn on more than one thing at a time
    19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
    20. My surface burners keep "clicking" even after the burner is light
    21. Oven door and door hinge help
    22. Oven temp sensor - how to change helps
    23. Repair tips and information on surface burner spark modules and igniters
    24. Some "how to set the self clean" on my range
    25. Stainless Steel Cleaning
    26. Surface burners wont work
    27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
    28. Test for F1 fault code
    29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
    30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
    31. Whirlpool Direct Spark Ignition (DSI)
    32. Yes, your glow bar igniter can glow red and still be bad!!
    Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
    GE Profile Gas Range oven light doesn't work even after changing
    Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Low flame
    so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
    Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
    Changed from natural gas to propane when new oven flames up the side top burners ok
    Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
    Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
    189 people viewed this question
    Top Jenn-Air Kitchen Ranges Experts
    Sal De
    Craig Butler
    Craig Butler
    Paul Carew
    Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
