Question about Franklin BAS-1595 Dictionary
There are some letters not working
Keys of letters (m,n,b,v,c,x,z) not working
Every letter on my key board worked the letter before the letter t will not work now.
1. Save your work.
2.Restart the computer.
3. If itdoesn't solve the issue get a can of compressed air and blow your keyboard, gentle with your finger nails do like if you are lifting the key as you blow it and it should remove any debris stuck under that key.
depending of your skills on computers I would take the keys off the keyboard and wipe it up.
If none of those options works your final choice will be replace the keyboard!
Dec 08, 2013 | Acer Aspire Computers & Internet
Left shift key types symbols not capital letters
it could be set to do so in system settings, like a shortcut. or there could internally be something inside under the keys which causes it to do that
Nov 03, 2013 | Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
Toshiba Satellite L855D keyboard does not work
Hi ,
there is a fuct key or fn key , look in your owners book to see what fn key yoou hit , too make it normal ...........good luck Roy
Dec 19, 2012 | Toshiba Satellite L855D-S5242 15.6-Inch...
Letter "p" key not working.
pull the key out of keyboard, Press the rubber directly using any material that would fit there and check if it works...If it doesnt work then probably the place where letter P is placed is damaged...
Dec 08, 2010 | Computers & Internet
The letter L key is not working
Check your regional settings in windows and make sure they are set correctly for the keyboard layout.
Jun 02, 2009 | Lenovo IdeaPad Y510 Notebook
Letter key on our keyboard doesn't work when you type on it
if handy with tools you can open KB an check all traces are good
if not need to use a HB pencil to re-trace grid @ non-working key
May 08, 2009 | Computers & Internet
Letter and number keys not working.
go to my computer>computer hardware>keyboard
click driver, then check if your device is working properly, if it is, click update driver.
Apr 20, 2009 | Microsoft Wireless Desktop 3000 Keyboard
You have a faulty keyboard. Need to change the whole keyboard since you cannot change just only one letter key.
Note: If machine is under warranty no need to pay for the repairs.
Apr 08, 2009 | Lenovo IdeaPad Y510 Notebook
Alphabet letters are off
That did it....I didn't know there was a screen calibration tool on it. Thanks for the assist!
Aug 19, 2008 | Garmin nuvi 350 GPS Receiver
Franklin BAS-1595 Dictionary Logo
20 people viewed this question
Top Franklin Office Equipment & Supplies Experts
Michael Vincent Cruz
Greg Cann
Greg Cann
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
